ENERGY AMPLIFICATION
0 Members and 125 Guests are viewing this topic.
Magluvin
Im not getting it yet.  If the caps are in parallel to charge, and series to discharge, then why sequencing the caps 1 at a time for discharge?  Something is not clear about this yet.
Mags
a.king21
What Tito meant by switching in sequence is:--  charge in parallel, discharge in series; and repeat  THAT sequence rapidly.
a.king21
John.K1
Quote from: Magluvin on March 12, 2015, 07:06:42 PM
Below is a pdf that I found interesting.
It shows how to make a capacitor that produces a magnetic field. Was a Tito quote. ;)
And near the end of the pdf is a circuit that reminds me of Titos first circuit. Also posted below.
Mags
I Have finished reading of that PDF. Have to say I need to read it probably more times as I do not fully follow. Long story short I have made extended TBC ( by using 0.127 mm thick brass sheets, thick plastic tape between ,height is around 50mm and the length around 200mm- making me 4 turns of spiral) and I am feeding it with HV from the flyback. I have also putted the 120W 220V halogen lamp in series with the spark gap between CD points. I can see nice very bright  sharp and load sparks (SG is not heating-possibly because  cold electricity) and the bulb brightnesses corresponds to the power in ( I go up to 18V @ 2.6A) How can I see a benefit from using this device?  The same effect I can get by using standard capacitor too.
The first thing I was thinking when I saw this special coil is the Vasmus device. He has something similar in his device too. Just he is using some permalloy or mu-metal.
Good luck
