ENERGY AMPLIFICATION
Magluvin
Hey IWD
I appreciate what you said. =]
I just believe that this needs to be investigated. I cant let it go stone unturned.  Im working on this a bit more in the sim to get most all parts for build as close to what is available.
I see that they are peaks. I see that if we had a large chart, that the 12w(at peak of ramp, not full cycle) vs the out peak, I think things will become more realistic to you.  Like the input ramp, average that from 0 to 12, thats 6 w continuous.
1k peaks, I find it hard to believe that even the spaces in between the out spikes, at 6w continuous, can equal over that period of time, the spike energy as a whole.
Lets say all in all, from 6w in, that from the spikes, we can generate 12w continuous, would that sound more reasonable?
8w out?   6.23995w out?
Now take the sim code above and get the pri and sec resonating!  hmmm  will that fill those gaps?
Have a bit of faith   Some here have it and some dont.    But no stone unturned.  k   =]
And I can use all the help I can get or even fresh ideas to try.
Mags
wattsup
Quote from: Magluvin on December 13, 2010, 01:13:28 PM
Actually that is what I had seen. Spikes going off the scope even at 5vdc and 10x setting and now way to pan up or down enough. lol
I am so glad you tried that. Can you post an image?
I never used a sim.
Don't even know how they work. lol
Only a build and my scope. I saw spikes.
So listen to this.
The ozone patent could have pulsed 5 primary working circuits, and at the ohmage each was at, they would have all felt the damped pulse just as hard. lol
CodeWebs
Wasn't sure where to post this since all the boards got moved around.  I found this paper really thought provoking though: http://nema-uqd.info/yahoo_site_admin/assets/docs/On_the_Principles_of_Permissible_Overunity_EM_Power_Systems.21335329.pdf
Thaelin
   With all the sim work going on here, there is one part of
the puzzle that has never been addressed. Frequency harmonics.
Its a known fact that if you tamper with the Vars, they disappear
right in front of your eyes. What about the 3'rd harmonic or say
the 5th? These two create havoc hell in power systems if not
tended to.
   The site on inductive heating shows a working coil of large size
and states it has "very high" circulating current. Tamper with that
and you put an extra load on the input. Would the harmonics do
that?  One way to find out I guess. Hmmm?
thay
Magluvin
Well, I found the need to get down to some basic Tesla. I think everyone should build a tesla coil once in their journey through the search for OU. It can teach you things through experience with it that you may never understand, and it also can get you to come up with some interesting questions along the way.
Like, what is the mechanism that determines the voltage across each winding primary vs secondary?  500v per turn, primary and secondary?  Why is that? What is the link that causes this equal volt per turn of the primary and secondary? How are the windings individualized amongst one another in that they seen to all find harmony at the same voltage per turn?  questions, questions.
I am posting some pics of what I have tinkered with lately, showing some things that I have seen but not yet able to do until I built the mini TC. The secondary is 6in tall, about 200 turns of 30awg  radioshack mag wire, and the primary is 2 turns of copper tubing, about 18awg. Discharge caps are Radioshack also, along with the 1kv diodes(2 in series in each leg, and the blue caps are 1kv 560pf in series with the mini neon transformer to limit how much gets to the discharge caps over time as it keeps the neon board happy and cool.
I tried a couple different low no. of turn primaries, even 1 turn, which consists of a piece of 2in copper pipe with  a slot cut in it. Worked pretty good considering the mass of copper and 1 turn.  2 turns is the highest so far as it in itself, is equivalent to a bifi coil where each of the 2 adjacent turns are 50% of the total voltage potential difference from each other.  I thought that was cool.
Ok, I am going to post some pics, I dont know if I can get them all on tonight, but Ill do my best, and if not Ill get them up tomorrow.
Mags
