ENERGY AMPLIFICATION
0 Members and 132 Guests are viewing this topic.
                                          ENERGY EFFECT AMPLIFICATION
www.oeko-energie.de intelligent consume  :    3      KWh/day
www.mtbest.net freezer solution                :   -0,8   KWh/ day
         oeko-energie.de heatsystempump     :   -0,18 KWh/day
        2      KWh/day
200W x 8 hours nightime charging + 100W x 8 hours daytime charging sufficient for the 2 KWh-netto
,after battery/charger losts, delivery
                        unchanged kitchen appliances
                            changing kitchen appliances efficiency(minimum):
There are heatconductor with better heat-conductivity and motors with generative coils with let
save 30% more:
                                                  heatconductor
Unites/Ukrania           HTM/ www.canlaser.com              in geral: graphit conductor
http://www.al-bernstein-industries.com/germ.html    Bai Wei Wu/China
                                                 electric motor
Larue Controller                   Shkondin-Motor                                                www.arestov.de
Zahardis/Nicolaev/Lam Dat-pulse powerCircuit   www.greenmotor.com     Meta-C:capacitive winding
In the 2 KWh/day consume are excluded the energy for warm/hot-water,
room ambient conditioning
and where there is a need : Air-to-water machines for po(r)table water use.
Let me do now a joke  ;) :
1 W energy per hour consume for the hot-water
1 W energy per hour consume for the room warm ambient conditioning
It was only a "loud outed dream" :-[ :'( :P based by :
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=22&ND=3&adjacent=true&locale=en_EP&FT=D&date=19931012&CC=US&NR=5252176A&KC=A  8)
                                            back to commercial reality ;D :
                                                heat energy converter
                       www.energie.pt + Ron Driver or Melvin Prueitts MECH
(this by Jacques Bernier invented thermodynamic panel for +/- 15 US$/ea. fob China/alibaba)
                Kanarev(up to 3000%efficiency)/Imris Inductionheater(up to 1000% efficiency)
the air2water machine,modified dehumidifier: f.e. Sullivan Shaun (youtube video)
up tp 150 Liter per day
to save water and energy I would prefer this use:
Duche http://www.inpama.com/index.php?content=invention&id=816
and a composting-toilett like here  https://www.habitaflex.com/
(instead that head-aching" habitaflex price I would prefer this south-african development in kind from an A-frame aluminium panel house for +/- 12000 US$/60sqm
http://www.powerprofile.co.za/ ,but outperforming the R-value by changing EPS to PUR,
this higher material price compensated through cheaper aluminium costs:
Aluminium production  by 0,01US$/KWh electricity delivering mobile power plants  and
less energy consuming production process,50-90% less energy N.A.S.A.-engineering
http://www.freepatentsonline.com/6551476.html )
                                      300US$-housing-modul
                      https://www.jovoto.com/projects/300house/ideas
                               the Essential core , core essential
                    https://www.jovoto.com/projects/300house/ideas/12735
                                                      price ?
                                                  compared
                       with www.geolitesystems.com "house-maker" and
                       (archive.org ? www.built-with-core.com "mini-core" )
              Which kind of driver for the water machine,the water-heating compressor
                                the room ambient conditioner :
do you know the "Swastika"-s,and the ccw/Left-hand and cw/Right hand orientation rules ?
                     Bionik-Professor Ingo Rechenberg/Berlin/FRG :
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=4&ND=3&adjacent=true&locale=en_EP&FT=D&date=19850314&CC=DE&NR=3330899A1&KC=A1
Die Erfindung geht von der Erkenntnis aus, dass zwischen Elektrotechnik und Strömungstechnik eine Analogie besteht.
Diese besteht darin, dass ein elektromagnetisches Feld um einen beliebig gebogenen drahtförmigen Leiter und ein Strömungsfeld um einen beliebig geformten Wirbel faden durch das gleiche Gesetz beschrieben werden, das Biot-Savartsche Gesetz. Die Grössen "Zuwachs an magnetischer Feldstärke" und "Geschwindigkeitszunahme" entsprechen daher einander. Da sich magnetische Feldstärke dadurch konzentrieren lässt, indem man einen stromdurchflossenen Leiter zu einer Spule aufwickelt, kann man auch in der Strömungstechnik eine Geschwindigkeitszunahme erzielen, indem man einen Wirbelfaden zu einer Spule aufwickelt. Ordnet man mehrere sich gleichsinnig drehende Wibel  so an, dass ihre Achsen auf einem Kreis liegen, werden sie sich infolge der gegenseitigen Induktion um den Mittelpunkt des Kreises drehen. Die Induktion wächst dabei mit der Zahl der Wirbel.Die Aufspulgeschwindigkeit steigt und die Wibelfäden nähern sich der Form von dicht an dic-ht liegenden Ringwirbeln. Das Geschwindigkeitsfeld, das diese Ringwirbel in ihrem Inneren induzieren, bildet den erstrebten Konzentrationseffekt.
                             this as kineto-mechanical principle/analogon:
http://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=li+yng+tyan&CPC=&IC=&Submit=Search
(by this idea I do not like the friction losts :
                                         surface treatment by www.bufo.ru tools
                                      http://www.bufo.ru/index.php?lang=3
Regarding the wear resistance of friction pairs – a radical problem of the machines and mechanisms – as of today according to our information the matter is as follows. When using the NUFM technology we can guarantee the doubling of their operation life.
When using the NUFM + Geo technology – 4–5 times more.
When using the NUFM + Geo+ technology – 10 times more.
                       Okay ;) ,under this condition now it becomes a little more tolerable ;D
                                               :o Nearunkaputtbar-Tech ::)
                                       chemalloy coating ? and
                "Motorkote"(TM) or similar as lubrificant probably a good solution)
                            Vortex/Turbo/Windhex : laminar to turbulent flow
                                 from chaos to calm     from calm to chaos
               anti-/matter is as description only an orientation definition
                  the egenerator for this energetic nonplusultra household ?
It can be this but has not to be :
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=20140203&CC=DE&NR=202013011233U1&KC=U1
the coils from cheap material like :
http://contest.techbriefs.com/2011/entries/electronics/1983-sodium-electrical-wire
but I like it easier  ;) NearZeroWatt-Society-Technology
Até logo
             OCWL
zdiblo
Some of the best ....
"Get a 4 handmade transformer then pulse one transformer, then at the secondary connect the three primary of the transformer in
parallel with
 magnets ..."
" we can actually add a lot of transformer and use the flux of the magnet.
That is three birds in one stone or a lot of birds in one stone. "
" DID BEDINI SHOW YOU HOW REALLY HE MADE HIS
COIL?  THINK. THE SECRET IS IN COILING OK!
ITS A REACTION IN THE FIRST PRIMARY WHEN PULSED AND MAKE A BIG KICK. "
" sometimes funny but it make sense like
Why there are male and female, why their organs exactly fit in every
ones organs. what a co-accidents "
"its like a worm gaining a little distance and after a while it gains a lot of distance, and the difference is TIME."
  ;) ;D
There are actually five parameters about energy generating appliances and the personal decision :
-household consume Wp/Wh per day
-worldwide habitants household liquid income (without/with credit potential)
-patentright saved/open source invention costs
-local manufactoring possibility and local explorable materials and recyclingability
-KWh/KWp-installation-price
More or less all WIPO-archive inventions,saved or open source,
in compact manner would explore an egenerator ,
which could be produced in the emerging countries for +/- 100 US$-50US$/KW and by calculated amortization over 10 years and with 5% taxation p.a. allowing an on-demand KWh-generating price about less than 0,25 US$cents.
[100US$/ea. KW generator costs x 0,125 (the 10 years and five percent tax) ] = 12,5 US$/year
/ 8766 hours per year for each KWh = "less than 0,25US$ cents" ;)
Cheap -      clean and grid-autonom      - energy will change the worldwide market rules,
this is "not really" wellcomed by established multi-national companies,when they will loose more than winning,independant from "cheap energy project/-s"participation or not.
The estatal taxation system is "urbanization grid dependant citizen" oriented and would also become to change the citizen tax payment condition.
"Urban Nomad living style" is also not wellcomed,against "I.ndustrial C.onsumer N.orm S.tandart".
A very simple "minimalism" example about "open mind" and social class interests:
                                          do it smiley simple :
http://inhabitat.com/polikatoikea-combines-small-space-living-with-urban-design-and-an-ikea-philosophy/
                                            1000 Euros/ea. (?)
alternatively: jovoto https://www.jovoto.com/projects/300house/ideas/12491
and the comment:
PanTau  Systems like Yours could be made for University Camps, but I have my doubt about the costs.
             "PanTau" shall know that this here is a Munich students living space solution,
                                         explored by their Profs.:
     the expensive -credit leverage based-"academical" solution,University of Munich :
                                 http://www.microcompacthome.at/?con=faq
                       38,000 Euros uninstalled/50,000 Euros fixed infrastructure installed
               This 38000/1000 relationship makes also the difference about
the commercial/"social open source project" or individual DIY egenerator production costs.
The triple macroeconomical credit system price leverage factor will become neutralized by free
                    C.A.D.-ware archive and 3D-Printer production condition.
    Without social overhead costs the G7-market products will become 90% cheaper.
Social overhead costs are the estatal and manufactory and administrating worker salaries.
              Salary of 3D-Printer is energetical food in Watt-Units or Joule or Calorie.
Writing about 100 US$/KW eGenerator production costs I will now show the serious material and production concept conclusions :
who knows economy price politics and the discount rates/quotes
differs between "list-price"and fob factory price per palett/container,
also between readytouse condition or as kit discount,
production rights exclusivity or standart production
                      average industrial administration behaviour:
1400%-"TM/utility modell/patent right saved" product price-list(without tax) maximum       +
selling price discounted by gross-buying = 700%
selling price discounted by kit-condition  = 350%
selling price discounted by open source standart (exclusivity-free) 100%
fob production viewpoint we have to differ price and value
How many bucks do the people pay for new machines ? Scratch rest value ? Demolition
How many bucks do the people pay for new cars ?         Scratch rest-value ? Demolition
How many bucks do the people pay for new buildings ? Scratch rest-value ? Demolition
Economically this formed material price-value relationship and monetary lost becomes amortisized :
                                                   book-value
                          And as powder/granular material new configuration and use
      This will become reality by the 3D-Print-technology and the Selfie-/REPRAP-process
                           3D Printer printing on-demand 3D Printer
                                       or in perpetuum/non-stop.
      The current 3D printing technology standart is sufficient developped(quality/quantity/precision)
      for the global political change .
     G.E. demonstration: 3D printed motor and generator parts,quasi ready to use
The "B.O.S.(built-operate-sell)factory" price has to be physically discounted,each production-unit has to become 99% cheaper:
                                  motor/generator production plant
before Roy Kessinger development : 250.000.000 US$ factory installation costs
with     Roy Kessingers concept       :   25.000.000 US$ factory instalation costs by same capacity
TARGET       3D-Factory                    :     2.500.000 US$                                        by same capacity
Modular      3D-Factory                    :        250.000 US$                                        by 1/10  capacity
                                             fabric-in-a-container-box
                                                    relocateable
                For 2KWh electriciy consume delivered by batteries I calculate :
                    2 KWh capacity for the net energy delivery ea. KWh 150 US$ (3000 cycles)
                +  2 KWh capacity DOD-reserve and equipment losts ea. 150 US$
                +  Batterycharger 150 US$
                +  In-/Converter 150 US$
                    2 KWh net energy per day delivery costs : 900 US$ + egenerator
            Would I install a 2 KW egenerator and controle elecronically(fuzzy logical) the KWp,
            the battery bank and related costs becomes obsolete.
           The egenerator as cheapest modell is a "rotary transverter",
            the KWh electricity costs will be less than the use of Nantennas which are
            production costs estimated in the 10 US$/sqm range .
           Development included winding :Ed Sines(US Navy)/META C Corporation/Wolfgang Hagedorn,
           core material: Lund University,UQM,PAM(Helmut Schiller),Green Ray
           magnets: METAMATERIAL(DARPA),Iron Nitrogen magnets,NASA plastic bonded powder
           Magnet array: Sankar Pat(Ronbach array instead Hallbach)
           transformer: Leupold(US Army "Magic Ring")
Commercial and technical approvement organisations like WIPO, international application requirement with translation costs 50000 US$ and technical approvement like TUEV for transformer,motor and generators up to 20 KW 25000 US$(TUEV Testlab in Budapest/Hungary) ,
this means that for each "egenerator/EMD-genset"
only +/- 1 US$ per unit will influence the price
if 75000 units will become produced.
Greater production numbers:
WIPO/TUEV           0,1   US$ ea./   750000   units
WIPO/TUEV           0,01 US$ ea./ 7500000 units
                                                              FAZIT:
WIPO approval process and TUEV approval costs are related to total  production -costs irrelevant.
                        A 24 hour/365 days net-free economy
                              grid-net and social-net free
                    Free shareware economy and barter condition.
                  Not politicians change the political rules but the machines.
Sincerely
              OCWL
zdiblo
Resonant LCR circuit = electromagneto-dynamical circuit or e-pump cycle (analog Carnot TD cycle)
