ENERGY AMPLIFICATION
nievesoliveras
Good job!
Is the pvc a 1/2 inch?
Also could you post a schematic of the connections?
Jesus
Magluvin
Hey Niev   Thanks  ;]
It is 1in pvc.
The light bulb on top is 1 turn aluminum tubing.  When I was lighting the other larger bulb, 4w 120v, using one wire from the secondary and my finger as the other connection, I found that it lit brighter on the end closer to the primary.
Gotta get back to work, lunch is over. =]
Mags
ramset
Mags
WOW!!
Buddy you have skills [guess thats why you make the "Big Bucks":}
Thought you'd like to see this,
User Darkspeed
from here
http://www.overunityresearch.com/index.php?topic=534.msg10316;topicseen#msg10316
Quote:
I started doing more experiments into the operation of a looped tesla transformer.
Imagine a conventional tesla coil where a unit of energy moves up and down the height of the coil like a bouncing ball.
Now bend that coil into a circle so the two ends meet and there is no longer a end to reflect that packet of energy, it is allowed to travel a complete circle.
I built a number of these but while they did function as a amazing display of sparks they would not spin a compass.
My biggest mistake was in thinking they needed to be high frequency, i was leaking power everywhere.
So I needed to slow down the transit time ( RF )
In a conventional tesla transformer this is done with a top load capacity or the addition of a ground at the base.
But this was a loop with a given wire length, so the next obvious choice was adding inductance.
Soft iron wire is a good choice for adding the required inductance to slow down the transit time.
I took a short, wide pvc former and wrapped it with a number of turns of soft iron wire in a single layer fashion.
The number of turns and the proximity to the tesla secondary allowed me to adjust the inductance.
It is a delicate balance between too little inductance and building a heater.
Two interesting things happened.
First I was able to bring the frequency down to a point that I was no longer wasting energy in transmission or discharges, so the packet of energy on its return trip was additive to the next impulse from the tesla primary. Delicate precise pulses adding over a period of time from a low power source.
Great levels of energy can be achieved this way before breakdown occurs.
The second was that i was now moving a magnetic node and antinode around the loop of soft iron wire in relationship to the node and antinode in the tesla secondary. A compass is useful in viewing this up to a point.
Laying a single loop of multi strand wire on top of the soft iron wire inside the tesla secondary produced some interesting results as well.
So for example if I was moving a induced magnetic field around in a circle at 6000 cycles per second and I put a wire in this path so as to drag this magnetic current down the length of this wire, it would be analogous of a generator passing a winding at 360,000 rpm. The result is very high voltage pulsed dc from a short low resistance wire.
He's busy getting his bench back up to speed
After a move.
Chet
Thanks Grandma
Magluvin
Hey Bud
I relied to the ebike thread, maybe didnt see.  ;]
Very cool stuff.  Ill check out the site tonight. Any pic over there?
Back later  ;]
and its good to be back in action.
Mags
Tito L. Oracion
Hi everyone, hope everyone is fine and cong hei fat soy  ;D
I just discovered something which is very natural and no need to use pump.
and i  am here again to share this rediscovery.
i will put some attachment on how can we make water freely flow without using any pump. What we only need to do is the starting point ok .
THE POINT IS WE CAN CONVERT THE TECHNOLOGY INTO ELECTRICITY!
Here they are:
  The siphoning Technology
http://www.youtube.com/watch?v=Sa_440OaQxE&feature=player_embedded#
