ENERGY AMPLIFICATION
0 Members and 56 Guests are viewing this topic.
pix
Quote from: Tito L. Oracion on March 31, 2016, 05:21:43 AM
The capacitor is actually just used to help in kicking but to get extra energy you have to use them with the coil. ;) 8)
Of course.
We put one and get many  :)
NickZ
  The thing does NOT work, or he would be showing it doing so.
  What works, is his arm's motion over it, until he stops moving it.
  However, there are magnet motors that do work. If you like noise.
that_prophet
I was thinking that this is so simplistic, that I was hoping that all of the evil spirits in this vast universe, could not find a way to poke holes in it. But I guess that those enemy forces still have a key word, torque, that strikes doubt in our unbelieving souls. How can I put this any clearer, these AC generators are just being used to wind up massive voltage. All of these many AC generators together, doing their massive rotating, only need to generate one single spark of current, (practically none). That is because the input for your DC drive motor, connected to the large 1000cm circumference pulley, only needs to be a single spark of current. That is because you only need to rotate this large pulley once, and it will give you a return of 1000cm of moving belt.
Then, when you run this 1000cm of moving belt through one to ten mini-pulleys, having only one centimetre circumference, this will translate into 1000 to 10 000 cycles of AC electricity. There is no more discussion needed, with only one spark of DC input, you are using the mechanical abilities of pulleys, to gain a return of 1000 to 10 000 units, (sparks) of AC electricity. This shows a clear multiplication of electricity, which means that you do not have to pay for it to be generated by fossil fuels, or the heat off nuclear fission. In essence, you are using this technology to multiply already generated electricity, there by gaining free energy.
that_prophet
Think about this, if you use one spark of electricity to rotate a DC motor once, connected to a 1000cm circumference pulley, which gives you 1000cm of moving belt, to run past 1 to 10 mini-pulleys of one cm circumference, giving you a return of 1000 to 10 000 units of AC electricity.
THAT IS ONE SPARK OF DC IN = 1-10 000 CYCLES OF AC ELECTRICITY OUT
(You would have to gain a net increase of power) = seemingly breaking the laws of Thermodynamics
Now try and tell me that you are not multiplying AC electricity, when you are multiplying total rotations
Torque is not a problem as torque comes from power generation = voltage times current
And we are just winding up massive voltage, (we only need one spark of current to keep this running)
Which, by the way, is exactly what we need, massive voltage=(pressure), to turn your drive pulley once
To make this a self powered mechanism,
All that you need to do, is add a full wave bridge rectifier, to convert your AC output
Into a DC output, which you run into your DC drive motor
Then you should be able to tap power off of both your AC+DC motors/generators
If you need more current capability, you could simply add more mini-pulleys + AC generators
http://free-energy.yolasite.com/
