ENERGY AMPLIFICATION
0 Members and 38 Guests are viewing this topic.
Now you have NINE threads going with the same mistaken delusion -- which you have been pushing without success for years now. When will you learn how pulleys actually work?
WHEN WILL YOU LEARN HOW FORUMS ACTUALLY WORK?
I think you need a medication adjustment. Please go see your doctor as soon as possible.
a.king21
that_prophet
If you are so convinced then put your money where your conviction is. Get someone to build the device for you.
A couple of hundred dollars should be ample for a basic model.
Then show us your video.
If it works I will personally reimburse your costs.
darediamond
Quote from: that_prophet on July 13, 2016, 10:28:31 PM
Think about this, if you use one spark of electricity to rotate a DC motor once, connected to a 1000cm circumference pulley, which gives you 1000cm of moving belt, to run past 1 to 10 mini-pulleys of one cm circumference, giving you a return of 1000 to 10 000 units of AC electricity.
THAT IS ONE SPARK OF DC IN = 1-10 000 CYCLES OF AC ELECTRICITY OUT
(You would have to gain a net increase of power) = seemingly breaking the laws of Thermodynamics
Now try and tell me that you are not multiplying AC electricity, when you are multiplying total rotations
Torque is not a problem as torque comes from power generation = voltage times current
And we are just winding up massive voltage, (we only need one spark of current to keep this running)
Which, by the way, is exactly what we need, massive voltage=(pressure), to turn your drive pulley once
To make this a self powered mechanism,
All that you need to do, is add a full wave bridge rectifier, to convert your AC output
Into a DC output, which you run into your DC drive motor
Then you should be able to tap power off of both your AC+DC motors/generators
If you need more current capability, you could simply add more mini-pulleys + AC generators
http://free-energy.yolasite.com/
While I like your Idea, I would like to point out the fact that You can badly get overumity with.committee of 300 çontroled ready made DC motors unless you rewind them,. You must make your own Axial Motor using Litz wire to get overumity. The Litz wire must be serially connected. The higher the strands in the bundle serially connected, the Higher the Toque and RPM of your Motor.
Good luck friend.
darediamond
Good luck friend.
