ENERGY AMPLIFICATION
Tito L. Oracion
i think using this technology we can make a man made Falls.
and from there we can make hydro electric plant right?
i want you to see this:
http://www.youtube.com/watch?v=cYCxiZoffDM&NR=1
http://www.youtube.com/watch?v=wgngVxdjXAQ
here is the secret to make it work:
THE CONTAINER SHOULD LOOK  A LITTLE LIKE AN IGLOO.
The plan is to make the water flow up above the container.
ramset
HHMMmmmm...............
Well Teets,
I guess we'll all be playin with buckets and hoses today?
Chet
PS
Why like an Igloo?
Thanks Grandma
wattsup
Sorry but the premise is wrong for that second blue design.
First of all, if you took that diagram with all bodies filled to where they are shown, the top small tank will empty into the top bottom tank and the suction will happen upwards for the bottom tank until you reach an equilibrium at which point any remaining water in the top small tank will just drop.
The video you showed of that guy with the water bottle means nothing and is only normal suction effect.
The analogy used of a glass submerged in water then lifted from the bottom up is not the same thing as your diagram. The glass has its bottom (now top) closed. Your diagram does not. Also work was done to lift the glass.
In general, you will never be able to get the water to keep in the position as shown in your diagram because water does not work that way at all. As you fill those lines they will just empty out into their tanks and overflow.
Nice try though.
wattsup
Doug1
 Tito
I have never run into anyone who has ever known of anyone who could truely make anything out of nothing as if from thin air or empty space.
So far as I know you can only convert one thing to another thing. A large amount of power would require a large endless source of something you could convert over. The effiecency at which it is used will determine the rate it needs to be replenished. If losses can be reduced then only a fibble amount of something at a sustainable rate will be needed to keep the process working. The way the JT works is what you should be focussing on. Consider bimetal windings and a current carring core with a demensional circumfrence of a loop antanna set at 7.5 hrtz.
Magluvin
Even the title above of the second blue diagram points it out that it will operate the same as the normal idea of siphon as shown in the first blue diagram.
I had not had a chance to try yet. will after work.    But I think that if we measured pressure per square in in the elevated cavity, lets say a wide cavity holding more volume vs a another elevated cavity of less width and volume, but at the same height, the pressure per square in should be the same at the top inlet hose that comes from the lower bucket, in both case. In your experience while swimming in the drum, =], you may have tried to elevated 2 different volume containers and felt that the larger was heavier, but that is only because of more square inches out of the surface of the reservoir.
Nice thought teets, but im doubting very hard now.  ;]  still not mad. =]
will test later today, but i believe I know what will happen.
Mags
