ENERGY AMPLIFICATION
0 Members and 49 Guests are viewing this topic.
Paul-R
Quote from: TinselKoala on July 14, 2016, 10:33:36 PM
Now you have NINE threads going with the same mistaken delusion -- which you have been pushing without success for years now. When will you learn how pulleys actually work?
WHEN WILL YOU LEARN HOW FORUMS ACTUALLY WORK?
I think you need a medication adjustment. Please go see your doctor as soon as possible.
He has a similar number of threads in the other forums. He's a religious fruit bat but at least he doesn't drive trucks through innocent people in the name of his God, which is something to be glad about, undoubtedly.
But he should still be banned. I have PMed Stefan and he hasn't replied and appears to have done nothing.
EMJunkie
Quote from: that_prophet on July 13, 2016, 06:36:44 PM
I was thinking that this is so simplistic, that I was hoping that all of the evil spirits in this vast universe, could not find a way to poke holes in it. But I guess that those enemy forces still have a key word, torque, that strikes doubt in our unbelieving souls. How can I put this any clearer, these AC generators are just being used to wind up massive voltage. All of these many AC generators together, doing their massive rotating, only need to generate one single spark of current, (practically none). That is because the input for your DC drive motor, connected to the large 1000cm circumference pulley, only needs to be a single spark of current. That is because you only need to rotate this large pulley once, and it will give you a return of 1000cm of moving belt.
Then, when you run this 1000cm of moving belt through one to ten mini-pulleys, having only one centimetre circumference, this will translate into 1000 to 10 000 cycles of AC electricity. There is no more discussion needed, with only one spark of DC input, you are using the mechanical abilities of pulleys, to gain a return of 1000 to 10 000 units, (sparks) of AC electricity. This shows a clear multiplication of electricity, which means that you do not have to pay for it to be generated by fossil fuels, or the heat off nuclear fission. In essence, you are using this technology to multiply already generated electricity, there by gaining free energy.
First I must appologise, I have not read this entire thread, however, I hope I may have some interesting information to ponder...
The transfer of Mechanical Torque to Momentum and back again is a time dependant process. In other words, it takes time to Convert the Input Motors Torque and Store this Energy in a Flywheel in the form of Momentum.
The Electrical Energy "Generation" process is a little different however.
For every foot-pound of Torque into the Generator Shaft, there is an equal and opposite foot-pound of Torque that restricts the Input Mechanical Energy.
This reflectance is called Lenz's Law!!!
Other losses apply, Friction windage and so on...
A belt and Pulley System, can put a Time Delay between this Input Forward Torque (Electric Motor Input Torque) and the Generators Reflected Restrictive Torque (Lenz's Law). Seen in the video that Forest kindly posted.
If you get the Timing right, which can be calculated, then your Generators Reflected Restrictive Torque (Lenz's Law) could be offset by 90+ degrees and this could add to the Input Forward Torque (Electric Motor Input Torque) and your system would see no Negative Momentum!!!
I hope this helps in your search!!!
Stay Dilligent, Keen and Determined!!!
   Chris Sykes
       hyiq.org
seychelles
HI ALL SOMETHING FOR YOU GUYS TO TRY..
seychelles
seychelles
