ENERGY AMPLIFICATION
0 Members and 55 Guests are viewing this topic.
leonelogb
QuoteSo what we need for making the extra coil or coils to work?
1. Aluminium
2. capacitor
3. diode
4. capacitor and diode
5. cap+diode+alum
6. none above
This is for 2M :D
God bless all.
cap+diode+coil that's all what you need for free energy. 8)
https://www.youtube.com/watch?v=iI47ZSRxVro
check it at 4:26
Thanks again!!! 8)
Magluvin
So now with this new information, there will be many ways of going about it with what was given
Closed core or open core?
Just 1 large winding tapped at 25% of the winding?
1 Layer?
Open ended extra coil but one end connected to the 25% winding?
Is the 75% bifi?  Is the 25% bifi? No bifi?
Is the 25% winding, which is said to be input, also the output?
Are any of the windings actually 'in' the core material? It kinda sounds like it the way it was stated.
Any safety measures so nobody gets hurt due to the high build up as was claimed?
Ya know, I have some hope for these things. Not as much as I used to, but I still have some.
Ive played with many many things over the last decade with this stuff. If I had made vids on all of it Id have thousands of vids, not just about 100.
Anyway, hopefully someone will get it. I havnt had lots of time like I used to to have to go through all the different variations that may need to be done to make sense of it all when given just tidbits. Heck hopefully it is just stupid simple as trying with an auto transformer, or just winding some core with 25% tap and ready to go.  But in my time on these, it is never that way so far.
Good luck
Mags
forest
How about a small Tesla  coil with extra coil attached in non-inductive relation to the secondary and primary , then a lot of thick step down in parallel around extra coil each with HF diode . The of course you must know the magic frequency and carefully protect extra coil from overvoltage (spark gap maybe) = most of Dally,Romanov,Ruslan,Akula and others circuits ?
Tito L. Oracion
Actually this thing makes small kick into big kick. 8)
There are lots of variation you can do with this thing but this is the real thing. ;)
AND OF COURSE THERE IS DANGER HERE OKAY, BE CAREFUL!!  :o
so try it first from small design ok.
happy experimenting everyone. i hope and i believe you can get it. ;)
The backfire of the 75% plus 25% coil is many times greater than the input AND it comes from the outside.
Then that big energy can be fired into another transformer then start collecting in the secondary of that transformer.  :)
NOW YOU TELL ME IF I'M NOT TELLING THE TRUTH!!! :)
A matter of practice and experiment ok.
Tesla says that just by holding the coil he can already know a lot of info in that coil.    8)
is it needed to know if its bifi? ??? :o
Tell me which is better.
We are already experimenting since lot of years already and still i have to detailed it?, what? :D
are we learning or what?!!!! >:(
ok according to tekla bifi is 250,000 times better than the ordinary.
am i going to repeat more?
if you don't know how to say thanks then just say => :P
more better at least i knew it.  :D
Hmm ::) ,using my tekla~ keyboard ;)  and posting now this 250.000 vezes/times/Male related
thinking by others,
" ok according to tekla bifi is 250,000 times better than the ordinary." :
Nikola Tesla, U.S. Patent #512,340, "COIL FOR ELECTRO MAGNETS," he explains that a standard coil of 1000 turns with a potential of 100 volts across it will have a difference of .1 volt between turns. A similar bifilar coil will have a potential of 50 volts between turns. In that the stored energy is a function of the square of the voltages the energy in the bifilar will be 502/.12 = 2500/.01 = 250,000 times greater than the standard coil.
from
http://www.nuenergy.org/nikola-tesla-radiant-energy-system/
When was the first (commercial) radio-station worldwide established and first broadcast ?
Radio-receiver/antenna technology ? Cable net or wifi ?
