ENERGY AMPLIFICATION
0 Members and 50 Guests are viewing this topic.
Magluvin
Hey Teets
Your thread here just broke 50,000 reads last night, and there has been 300 since.
How bout a little bit of something real. just a peanut.   we just might get to 100k reads by the end of the week.
Just a popcorn seed.   you like seeds?  ;]
Mags
forest
Mags
It's about the weight of ALL water in container. It makes pressure for any point inside water. This pressure is weakened when water level is falling.
That's I think about it. If ether is under pressure then any hole will make a siphon. Sustain hole and we have continuous flow of ether via siphon. But how to make this electrical siphon ?
Magluvin
Hey Forest
I even tried to have an air bubble at the to of the water filled inverted container, thinking possibly that the water weight would have a greater effect by decreasing the pressure of the bubble, but still, pounds per square inch beats all ways.
I tried the Trisils.  I dont know if Im doing anything wrong, but they dont work as suspected. The Sidacs seem to do very well and very predictable.  But they dont beat a spark gap.   So what device can we use to truly come close, or even better than a gap?   Searching for the silent solid state gap.  Unless the rotary switch is the way to go ultimately.
Mags
TEKTRON
I've always wanted to try this but haven't had time.
A boiler maker once told me that when they make large water tanks
they fill them with water to pressure test them. When it comes time to
drain them, if they forget to open the vent on top, the tank will crush
like a beer can. so I came up with this
Magluvin
Crush the tank.  Exactly.  Because thats where most all the pressure per square inch is on the surface of the tank.  But the top hose inlet, is lets say 1 inch, and thats all the pressure it gets.  So if you look at the surface of the tank, lets give it 2000 square inches, compared to the 1 inch inlet, the water in the siphon tube to the right will weigh enough to siphon from left to right, until the source is depleted or both water levels are equal.   I wished it worked, trust me.  =]
Mags
