ENERGY AMPLIFICATION
0 Members and 35 Guests are viewing this topic.
Dave45
I like your quote its from the Torah isn't it?
Im not going talk about certain things but heres something to look at, the buck converter it loses momentum when the switch is off (loses voltage) now think about this a ring magnet is used in a magnetron to spin the electron that is released from the heated thorium, now take a pancake coil an place in the center of ring magnet, whats going to happen when electron@re ran through the coil- the ring magnet will accelerate the electron, adding voltage even when the switch is off.
I havent tried this but was thinking about it, worth a shot.
Maybe someday i will talk about the other, maybe not.
tim energy
let one arm of the coil be connected already to the cap when charging it so that it becomes more efficient when caps is discharge , all we need is very small movement of the electron to produce a large output!
P.S. Bigger magwire makes strong magnetic field isn't it?
tim energy
Try discharging many caps sequentially on a coil in a high voltage dc then make a pulse with a small current :)
its not the rate of discharge that is important here, its circuit arrangement of capacitor discharging separate from the source to the coil ala tom bearden.
:-*did you try discharging many caps sequentially on a coil? and charging them sequentially also?
take note: NO BATTERY DISCHARGING!
sooo ... how we merge bearden circuit with tesla ozone patent circuit .... titonium ... please
tim energy
discharging a capacitor in a series wound bifilar tesla coil is the real source for free energy :'(
bearden degenerative and tesla ozone
Dave45
We spend most of our time just looking for a direction, let me give you about eight year head start.
To understand this look at electrolysis, the electrodes put tension on the water molecule an pull it apart. The same thing can be done to our atmosphere a high tension circuit such as the ozone patent creates a stress on air molecules (nitrogen and oxygen molecules) and separates electrons and protons, it actually creates a positive cloud around the negative electrode and a negative cloud around the positive electrode.
Now all you have to do is collect, opposites attract and collect always.
A coil that is pulsed using electrons will become negative and when its fied collapses it will pull positive energy from the atmosphere (cold electricity)
If you then take that positive energy an run it into another coil it becomes positive and when its field collapses it will pull negative energy from the atmosphere.
Combine the two circuits, one to create the tension and the other to collect.
