ENERGY AMPLIFICATION
Dave45
An example of the collection circuit, not the exact circuit.
The diode between the coils dampens the oscillation must be moved.
This is just an example not the exact circuit but enough.
leonelogb
I like your quote its from the Torah isn't it?
Im not going talk about certain things but heres something to look at, the buck converter it loses momentum when the switch is off (loses voltage) now think about this a ring magnet is used in a magnetron to spin the electron that is released from the heated thorium, now take a pancake coil an place in the center of ring magnet, whats going to happen when electron@re ran through the coil- the ring magnet will accelerate the electron, adding voltage even when the switch is off.
I havent tried this but was thinking about it, worth a shot.
Maybe someday i will talk about the other, maybe not.
It's from old testament, Book Esther 4:14.
Thank you for reply Dave45. :)
I have been follow you hard work in ice an schematic that you have been share with us for love. I just want to tell you Thank you.  :)
I will respect you decision, you know what to do and how to with with wisdom. Blessed!
Dave45
A paradox
In the book of Ezekiel GOD tells us exactly how to achieve antigravity, Ezekiel describes HIS chariot in detail.
This is the paradox if we are not supposed to be using this why would HE do that. The wheels are coils except for the one that is parallel to the ground.
I've been stalled for a while thinking about this.
Dave45
Current is a product of electron flow it moves along the outside of the wire in the opposite direction of electron flow.
Nature seeks neutrality this is the reason electron flow is possible in the first place, a high charge moving towards a low charge, this movement creates a current seeking to neutralize the source, the electron is negative the current it produces is positive.
When two charges of opposite polarity meet they become neutral, this is why a normal transformer can never achieve overunity it cancels itself out.
