ENERGY AMPLIFICATION
Tito L. Oracion
Quote from: Doug1 on February 03, 2011, 12:09:59 PM
Tito
I have never run into anyone who has ever known of anyone who could truely make anything out of nothing as if from thin air or empty space.
So far as I know you can only convert one thing to another thing. A large amount of power would require a large endless source of something you could convert over. The effiecency at which it is used will determine the rate it needs to be replenished. If losses can be reduced then only a fibble amount of something at a sustainable rate will be needed to keep the process working. The way the JT works is what you should be focussing on. Consider bimetal windings and a current carring core with a demensional circumfrence of a loop antanna set at 7.5 hrtz.
Hi doug1 good day  ;D
I want to change your perspective and belief ok.
Believe that there is God, There is Jesus, believe that everything is created out of nothing READ THE HOLY BIBLE OK  ;)
Now!, We were created in his own image and likeness ok read GENESIS ok
Now!, For every problem there is always one sure way or solution ok, its only the state of your mind that makes something into impossible, now believe even you don't see it that everything is possible ok?  ;)  ;D
its always depends on the design  :)
We are in an open path, everything can be a source of energy, everything that is unbalance possesses an energy.
Remember a Triode?, the third added portion only needs a little power to control a huge amount of energy right?
And do you remember the yin and yang belief that it can control a huge amount of energy using a little energy ok.
Now, also why is the jt become reality? do you know that before it was discovered, it is impossible right?
We are now nearing and nearing  ok  ;D
NOW! NOW! NOW  ;D here is my last and closest clue to the water trick:
       WATER ALSO AND ALWAYS SEEK AN EQUALITY OR BALANCE, THEREFORE THAT WE SHOULD ALWAYS PUT IN OUR MIND THAT WHEN THERE IS UNBALANCE MASS THEN THERE IS ALWAYS STRESS AND PRESSURE AND ENERGY SEEKING COMMON DENOMINATOR  ;D
The question should be how to use the whole weight of the water?, try the point of contact.  ::)   ;D
Tito L. Oracion
Hi everyone
BE STILL AND KNOW THAT JESUS IS GOD, IF EVERYTHING IS FAILED, NO WORRY JESUS IS OUR HOPE OK DON'T PANIC!  ;D
THERE IS NO DEATH IF YOU ARE IN JESUS, BELIEVE ME  :)
THE DEATH IN FLESH IS JUST THE BEGINNING OF ETERNAL LIFE.  :)
NOW! WANT TO KNOW JESUS MORE? HERE IS MY TIP TO ALL OF YOU TRY TO SEARCH CHARLES STANLEY, HE PREACHES THE REAL WAY TO JESUS, BELIEVE ME EVERYONE.
WANT TO KNOW THE TRUTH? TRUST ME THAT'S THE WAY.
ALWAYS HUMBLE YOURSELVES TO THE LORD JESUS. HELL IS REAL.
JESUS WANT TO SAVE OUR SOUL, JUST REPENT AND HUMBLE YOUR SELVES TO HIM. LOVE YOU ALL BRO.
READ THE BIBLE, DON'T LEAN ON YOUR UNDERSTANDING TRUST JESUS.  :)
ramset
Teets
Good you have found your salvation,also good you want others to experience this!
There are no boundarys to that power,but we seem to have some boundarys in the energy department?
Chaloopa is still waiting to wash your car,
Can you really run a refridgerator on a watch battery?
Or do you just "Think" you can?
Our water is all frozen here, so she can't do any washing till spring.
She's been dusting off stars to keep busy!
Chet
Thanks Grandma
ramset
How about a Toaster ?
On say A triple A battery? That would be Nice!!
Chet
Thanks Grandma
forest
Hey
Give me home heater 30kW started from 9V battery and I would be happy  ;D
