ENERGY AMPLIFICATION
0 Members and 657 Guests are viewing this topic.
tysb3
Dave45
Cadman
Tito
Don't you think you have kept people guessing long enough? Your first working device was based on these patents wasn't it.
Carlos Benitez Patents
17811
14311
5591
121561
Calculations per patent 121561
Desired Output Current (amps)                           20
Frequency of AC supply                              500
Watts furnished to the supply transformer                     100
Efficiency rating of supply transformer (%)                     80
Impedance of oscillating circuit (ohms)                        10
Watts delivered by secondary of supply transformer               80
Supply transformer secondary, volts needed to charge condenser         400
Current delivered by secondary of supply transformer (amps)         0.2
Coulombs delivered to condenser by secondary of supply transformer      0.0002
Condenser capacity required (microfarads)                     0.5
Inductance of oscillating circuit (millihenrys)                     0.028125
Convert mh to cm                                 28125
Oscillations per second                              42441.9825696732
Oscillations per spark                                 42.4419825697
Current discharged by condenser (amps)                     19.9999945661
Cheers
Cadman
Bob Smith
Quote from: Dave45 on December 28, 2016, 09:16:42 AM
See the open coils might they be ionizing the field  ;)
Yes, about 7 minutes into the video, that is what struck me as well. I don't speak Russian, but "resonancia" keeps being mentioned, and so balance between coils to allow for sympathetic resonance must be important.
I noticed a few other things about this setup:
- that the off time for the square wave pulse in the duty cycle was much longer than the on time.
- that when the square wave pulse went off, the negative energy began to show up.
- that the system seemed to be load driven - more bulbs lit, more amperage drawn, wider negative on the sine wave following the square wave impulse.
Tito has mentioned a number of times the importance of a unidirectional pulse, which I take to be a positive pulse. I would see the square wave impulse as proof of concept in this.
The other thing that seems evident to me in this is the push-pull factor is important. I think the scope shows that this in fact is happening, and I believe it also demonstrates with the two open coils in the primary what Dave has been saying.
For me, the two open coils produce their ionizing effect by widening the window of potential difference between them. I would see that in this way, they can draw in greater amounts of charge from the ambient electrostatic medium.
Bob
