ENERGY AMPLIFICATION
0 Members and 52 Guests are viewing this topic.
Dave45
The buck converter is a better candidate
The electron always moves through the load
The freewheeling effect
The downside the electron losses momentum(voltage) when the switch is off.
Dave45
A permanent magnetic field excerpts a force on a current carrying wire, if the wire is fixed and cannot be moved does the permanent magnetic field excerpt a force on the electron within that wire?
Could we use a permanent magnetic field to accelerate the electron within a wire.
Dave45
Can we subject the added coil in this diagram to a permanent magnetic field and add acceleration to the electrons.
Say a pancake coil inside of a ring magnet.
leonelogb
Dave45 Thank you for Enlighten us. :) :D NEXT ;D AND NEXT  8)
watch this video: https://www.youtube.com/watch?v=YPiUSCQIKC4
Dave45
Akula shows the system being pulsed by an npn transistor, if you study the caps- C1 just doesn't work.
But if you use a pnp transistor it works
