ENERGY AMPLIFICATION
0 Members and 52 Guests are viewing this topic.
leonelogb
Tito talk to me what is missing in this pic. ....A diode??? :D
Quotelet say we have a awg#14 wire as core and a awg#22 then make the awg#22 a bipilar and perpendicular to the awg#14. The source is AA batery, then pulse it and check the energy created in awg#14 ;). ooooops: i forgot, there should be an extended wire of atleast awg#8 connected in the awg#22 to do the magic.  ;D
QuoteThat is a joint coil the primary and secondary right?
endlessoceans
Quote from: leonelogb on December 30, 2016, 10:12:17 AM
Nonsense!!
THAT diagram is taken from a Patent that requires highly radioactive components in order to amplify the input..  DO NOt confuse OVERUNITY (which doesn't exist) with FREE ENERGY (which is all around us).
Tito is a LIAR and has been wasting your time for years.
Dave45
http://www.explainthatstuff.com/how-magnetrons-work.html
The ring magnet spins the electron but does it accelerate the electron,
Dave45
The buck converter shows us the electron can be used over and over again its energy is dependent on its acceleration.
If the battery is 12v when the switch is on you will have 12v across the load but when the switch turns off the voltage drops, the electron keeps moving through the circuit but its attractive force has been removed so it slows down the voltage drops.
Dave45
So if we take a pancake coil an place it in the center of the ring magnet then run electrons into the middle is the magnetic field going to accelerate the electrons.
