ENERGY AMPLIFICATION
0 Members and 204 Guests are viewing this topic.
Dave45
its just very simple friend, no hendershot, just hubbard ok. [/size]
👍👍👍[/size]
mikemongo
The message being conveyed is that reactive power can be made to do something useful.  In this case it is creating high voltage for an ozone generator.  Charge the capacitor during open time of the commutator, discharge the cap through the inductor during the shorted time of the commutator.  Phase difference between charge time and discharge time makes this REACTIVE POWER.
leonelogb
I have a question; In ozone patent the large capacitor represented by the letter L is the bifilar-coil 512,340 tesla patent?
Which also forms part of the coil with letter M??  ???
Dave45
Any suggestion about the connection who make the magic with the secondary to primary coil-bifi ?
QuoteNow Dave45, I know that you know how is the connection of the primary-bifilar with the secondary, who is who actually does the magic. Please if you are so kind to put the diagram here. We will thank you very much!
Tito L. Oracion
Quote from: Erfinder on January 11, 2017, 08:30:01 AM
Thanks for your honest answer.....forgive my intrusion.
its okay sir, no damage happen. ;)
The diagram is actually first : charging the capacitor because it is in parallel by the battery. but as it charge the caps, movement of electron will be done as it charge, and magnetic field is build up and energize the motor and turns the fan and as it turns, the shorting action happen, and making a short discharge between the battery and the capacitor. BUT! in that short short, things happen: make low self induction and high self induction in the coil of the motor but higher volts dictates and charge the caps to a high potential, and also make very high voltage at the secondary and obviously make an ozone. its like using one bullet in so many birds. ;)
in time of shorting and break, potential will develop in small and high coil of the transformer and induce current in battery and caps and since caps discharge first then caps will be filled first.  :D
and that is what i honestly understand in that circuit sir. please correct me if i'm wrong ok.
Thank you very much sir
God Bless.
bye. :)
otits :)
Dave45
I see an lc circuit generating high voltage into the secondary, it does just what the patent says it does generates ozone.
I don't see how repacing the cap with a bifilar coil will pull any energy from the setup, its basically a bipolar tesla coil.
