ENERGY AMPLIFICATION
0 Members and 220 Guests are viewing this topic.
Magluvin
Emm, maybe its just an inductor. The rectangular conductor is neato.  ;D
The smd transistors these days are so low in on resistance, very high currents and no heatsink.  Im working with some IRLB3034 mosfets. 1.4mohm on resistance.
Mags
Dave45
Been thinking about the Don Smith device.where the primary is inserted inside the two secondarys, the premise of this device is to catch the electric field of the primary.
For one thing the secondarys could be gold plated using electrolysis and also i wonder if the primary was encased in glass would there be any bemf absorbed by the primary.
Im not sure the system should be such high voltage, i played with it a bit back in the day and it was very unstable. One thing i did was covered the primary in screen wire and got some crackling noises but like i said the extreme high voltage makes the system unstable.
Magluvin
Quote from: Dave45 on January 22, 2017, 01:22:11 PM
Ya know, I played with the primary circuit on Circuit sim as it has an adjustable spark gap component in the list. I set it for 1kv and adjusted an input to a  transformer to sim the nst. I was surprised that the circuit can get the LC of the primary going. The nst is setup with the center tap screw and the outputs send charge to the cap full wave rectified. The freq of the input and the cap n primary coil need to be adjusted to get the lc going well.
But now I see that the primary circuit does work as shown. ;)
Then the big sec coils with cap on one would probably need to be designed to operate at the same freq as the pri LC.  Been looking at this on and off. There may be something to it.
Mags
luc2010
Quote from: ]
Whats going on in this fig?
/quote]
Hello,
       a tesla coil? plus ''strange'' capacitor that separate the air?...
All i can see!! Sorry
best regards
luc2010
sm0ky2
There lies a difference between old world sketches
and modern day schematics
The following is my attempt to translate this drawing
Into something you understaH(nd
Point (A) is the vitreous charge and point (B) is the resinous
The difference in potential creates a current between points
(K) and (G) through motor(H).
This creates a difference in potential through wire (C)
Between capacitors (D) &(F) with respect to cathod E
of the vacuum tube. Which creates an ionic wind in direction
of the fan on motor (H).
The current through motor (H) induces a current
through primary (M)
Which manifests itself as a potential (P) through coil (N)
The ionic wind then creates a potential between points (K)
And (M) through capacitor (L) which can be viewed as a
Double-plate capacitor with higher capacitance than the rest
Of the circuit.
