ENERGY AMPLIFICATION
0 Members and 45 Guests are viewing this topic.
citfta
Erfinder,
Sorry I did not see your PM until just a few minutes ago.  I think what you are wanting me to see might be explained by figure 4 of the Alexander patent.
Carroll
jbignes5
"Self-induction coil for condenser method in conjunction with oscillating transformer. Adapted to Thomas clockwork and condenser 1/2 mfd. mica on hand (one of the two small condensers). Capacity given 1/2 mfd., break also given: wheel of clockwork breaking and making contact has 180 teeth, turns about 20 a minute. This gives breaks =60 60 per second."
"As has been stated on a previous occasion in connection with this subject, to enable a considerable rise of pressure to take place in a circuit, the same must be tolerably free from inductive influences of other circuits. It follows from this that, although with a secondary in loose connection with a primary a very high pressure is obtainable, yet the pressure will never be as high as when an "extra coil" not in inductive connection with the primary is employed to raise the pressure, because the secondary always reacts upon the primary thus dampening the vibration, while the "extra coil" does not react in such a manner, the rise of pressure being simply due to the factor pL/R."
This was taken from here: http://www.bibliotecapleyades.net/tesla/coloradonotes/coloradonotes04.htm
July 12th entry.
With reading the patent he states the motor coils are the high self induction coils. Although the components are rearranged slightly it is essentially the same thing.
  The primary of the oscillating transformer is the two turn of the ozone patent(also the extra coil) and the capacitor, with the secondary being the high voltage solenoid feeding the air capacitor or Ozone plates which is an open circuit and not shorted but by the induction across the Ozone plates.
In the patent it states:
" apparatus devised for the purpose of converting and supplying electrical energy in a form suited for the production of certain novel electrical phenomena which require currents of higher frequency and potential than can readily or even possibly be developed by generators of the ordinary types or by such mechanical appliances as were theretofore known. This apparatus involved means for utilizing the intermittent or oscillating discharge of the accumulated electrical energy of a condenser or a circuit possessing capacity in what may be designated the "working" circuit or that which contains the translating devices or means for utilizing such currents. In my present improvement I have utilized appliances of this general character under conditions and in combination with certain instrumentalities, hereinafter described, which enable me to produce, without difficulty and at very slight expense, ozone in any desired quantities. I would state the apparatus which I have devised for this purpose is capable of other and highly important uses of a similar nature, so but for purposes of the present case I deem it sufficient to describe its operation and effects when used for the purpose of generating ozone."
Where do you get energy amplification from?
Although he does say that this process can be used for other and highly important uses of a similar nature he doesn't go into it in the patent you referenced.
In my experience this system takes DC and converts it to a high voltage freely oscillating pulse to be applied across the plates which is an air capacitor designed to generate Ozone. Yes there are other uses for this system but nothing is said in the patent to give a clue as to it's operation or the theory behind that operation. Not in the patent. In order to figure out the other uses all one needs to do is look at other experiments he did in that area. The above link should help all to figure out what he meant by other uses.
But for you I will tell you something about these systems.
"Owing to this feature I expect that this method of raising the e.m.f. with an open coil will be recognized later as a material and beautiful advance in the art. No such pressures — even in the remotest degree, can be obtained with resonating circuits otherwise constituted with two terminals forming a closed path. It is also a fact that the highest pressure, at a free terminal, is obtained in that form of such apparatus in which one of the terminals is connected to the ground. But such "extra coils" with one terminal free may also be used with ordinary transformers and by using one such coil on each of the terminals of the transformer, practically any spark length may be reached."
AGAIN: "No such pressures — even in the remotest degree, can be obtained with resonating circuits otherwise constituted with two terminals forming a closed path."
The secondary of the Ozone patent is an open path. The only thing closing it is the induction between the plates of the air capacitor.
The extra coils he talks about is here:
"In order to produce the greatest possible movement of electricity through a region of the earth in accordance with the plan involving use of a single terminal oscillator, as here experimented with, it is desirable to obtain in some way a large capacity on the free terminal. This is connected with difficulty as spheres get to be too large with moderate tensions and when the tensions go into the millions, streamers can not be easily overcome. The streamers involve loss of pressure just as leaks would on a water pipe which is closed at one end. Large capacity is obtainable in a number of ways of which some are:
1) a coil wound for maximum capacity (internal). The turns are so disposed that between the adjacent turns of layers there exists a great difference of potential, as much as the insulation can stand."
On a side note Tesla figured out that the insulation can be enhanced by the use of an oil bath of the extra coil. Careful attention to extracting all the air one can from said coil to reduce insulation destruction on extreme pressures should be followed.
The bifilar coil is that capacity he mentioned as number one on the list. This was explained in the July 16 notes.
The second picture fig.2 is the schematic he shows for moving the maximum currents through the ground, shown below.
And the figure 1 diagram is what Tariel Kapandze based most of his devices on. With the ground wire going through the center of the transformer. Is it possible to tap the extra coils energy? Thats the million dollar question?
Dave45
Seems to be a lull here, has anyone considered the possibility that you are getting a transformer type reaction between the generator coils.
Grumage
Dear Dave45.
10/10.....
Good effort.
Kind regards, Graham.
jbignes5
 It's not a theory, it's an explanation given by the author of the patent you are trolling.
The only theory here is yours about energy amplification.
AGAIN I ask, Where do you get energy amplification from that patent and where is your demonstration of your theory of energy amplification and how it relates to that patent, Tito?
