ENERGY AMPLIFICATION
0 Members and 242 Guests are viewing this topic.
allcanadian
@Tito
QuoteHow do you think He accumulated electrical energy? [/size]I am challenging everyone to participate to answer this question to help everyone.
In my opinion this is the most relevant comment posted here in a very long time. One can go off on any number of tangents or subjects however the fact remains that if someone cannot grasp the concept of accumulation versus dissipation then they will never truly understand how any FE devices work. As well once the basic concept is understood it should become obvious that it can be applied in any number of ways to almost anything. At this point I will introduce a new concept... Perception creates and transcends reality. That is if we change our perception of what we think is possible we can change the reality of what is possible.
Did you know I have the miraculous ability to cause Heat to fall to the floor then rise back up when most all others believe Heat always rises?. It is an extremely complex and mind boggling procedure but it can be done. First you stretch out your arm then drop a sodium acetate hand warmer onto the floor which causes it to activate and start generating heat... congratulations you have done the impossible. Heat has fallen as Latent or "hidden" heat which is cold and then transformed into sensible heat which is hot causing the hot air to rise. We could speculate that hot and cold electrical currents work in a similar manner whereby the energy in a current may be latent within the flow of free electrons we call a current.
I can also cause heat to contract and fall rather than expand and rise... a little trick I learned from victor schauberger.  I believe Victor was correct when he said our civilization is based on the primitive concepts of consumption and the dissipation of energy as heat versus growth and the accumulation of energy without heat. Our understanding is so completely backwards that some people still think cutting down entire forests of trees and burning them for energy represents growth. Oh the humanity.
A tree can grow without generating heat, a tree can accumulate water and minerals and energy in itself without generating heat. A tree accumulates energy in itself to grow and as it grows it accumulates more and more energy. It is interesting to note most FE devices have these same qualities and the greater the load the greater the power generation with respect to the load. It may be that most are barking up the wrong tree and they should spend more time studying nature.
AC
sm0ky2
Circuitwise the motor is just seen as an inductance
(Not much reactance since it only powers a small fan)
So in that sense it's just like the coil
The dc motor is always powered, so is the + of the cap
It doesn't discharge through the primary except when it sparks.
Inductance through the primary is what needs to be
considered in the LC tank.
The inductance through the motor that charges the cap
Is less important to the scheme of things.
What it affects is the capacitor charging time.
Not the resonance of the tank.
forest
Zephir
Quote from: allcanadian on February 18, 2017, 06:22:28 PMif someone cannot grasp the concept of accumulation versus dissipation then they will never truly understand how any FE devices work
In my theory overunity occurs during negentropic metastable phenomena like the overheating or oversaturation with release of the accumulated energy.
wattsup
@all
OK, so maybe I need to take this a little slower.
So I am putting up the same patent drawing as before.
For now, forget there is a rotary switch (H). Consider supply to be DC positive (A) and negative (B) and the fan motor brushes overlap as in a regular DC motor.
So the fan motor to work needs what? It needs a positive and a negative potential to rotate. Right or wrong?
The negative is going directly to the fan motor coil (C) so how is the positive going to the motor. Yes, the positive goes from (A) to (K) to (L) to (M) to then land on the (G) terminal that feeds into the motor coil (F). RIGHT OR WRONG?
At this point you all need to stop and contemplate what this means. If there is no positive potential at (G), the motor will not turn. Right or Wrong? So what does this mean?
In standard EE we are told (or convinced) that the "electricity" flows in the wires so in fact if it does flow then there cannot be a separation of potential because in any flow of anything, there is no compression possible and since all the flow follows in a line, it all needs to be the same flow. So the construct in itself is faulty from the start. We have just been trained to disregard this discrepancy for the sake of sanity (given the construct touches on insanity) or what I do not know. But regardless, the positive still needs to arrive at terminal (G) if you want that motor to turn and that fact will never change.
So the capacitor (L) and the Primary (M) are now both positive biased while the motor turns. This mean the complete winds of the primary (M) are positive biased in the "direction" (hate that word but nothing better to use) going from (L) to (M) to (G). Looking at drawing let's say it goes from the right through (M) to the left going to the (G) terminal. The capacitor at this usage offers some "resistance" to feed the fan motor while the primary (M) offers almost no resistance and the fan motor turns.
While the fan motor turns, why should the capacitor increase in charge above and beyond what is supplied by the battery feed (A) and (B). IT CANNOT. The capacitor is no more no less then a conductor with some resistance because its capacitor function is negated by the fan motor sucking juice all the time.
If you guys can absorb this thus far, you will understand that up till now and while the fan motor is turning the primary (M) never saw a negative potential because the negative potential is stuck in the fan motor coil (C) while the positive went "through" (L) to (M) to (G) to then be stuck in the fan motor coil (F).
OK. Now let's go the the next step and include the rotary switch (H).
When H closes and connects (K) to (G), the positive still enters the fan motor coil (F) as it did before although with less resistance since it no longer has to go "through" (L) and (M). But now, with less resistance it hits the primary (M) as well but now from the left through (M) and lands into the capacitor (L). SO THE WORKING PRIMARY NEVER SEES A NEGATIVE POTENTIAL. IT ONLY SEES A POSITIVE POTENTIAL FROM RIGHT TO LEFT WHEN (H) IS OPEN AND FROM LEFT TO RIGHT WHEN (H) IS CLOSED.
In normal EE we want the primary to change polarities so that change can be coupled to the secondary as per the turn rations and produce the required output. But what Tesla has done here is not use both polarities across the primary (M). He just changed the "direction" of only one polarity, the positive and how it is biasing the primary (M) and the secondary not giving a shit on why the change occurs, sees this and produces output. Change is change.
Now, if we consider that to measure the power consumption of the battery, we need to have both polarities in the consumption loop, what Tesla did here is bypass that and only use both polarities to turn the motor but only the positive polarity to produce the OZONE.
All this is more then logical. It is based on Spin Conveyance Theory and not standard electron flow theory. At the time when Tesla saw this effect, he did not know of SCT and being the honest camper that he was, you could only describe the effect to the best of his observational ability. Hence we say the capacitor in the Tesla patent discharges otherwise how is it possible to produce Ozone? But with SC, you can get the same observational result but now with a more precise rendering of the real function. Amazingly and instinctively, Tesla also solves the problem of Half Coil Syndrome since the primary has the fan motor coil in series when the positive is from right to left and the capacitor is in series as well when the positive goes from left to right.
Look, I know you will never read such a description of the Ozone patent anywhere else on the planet so guys, instead of just shoving me around like a piece of shit, I suggest you look at this carefully. The TOP will never be properly described by conventional EE and I already know that a good number of you will catch onto this quickly via SC. Otherwise you will be stuck to explain to us all how the primary changes potential when it never sees a negative. The Tesla Ozone Patent is using an ALTERNATING POSITIVE BIAS on the primary to produce the output. Sounds crazy but new ideas usually do. That I cannot change.
I'll stop here because I know those who read but never post here will want some time to digest this. Bon Appetit.
Note to guys PMing me. Please better you post your questions to me on the appropriate thread so others can read them as well.
wattsup
