ENERGY AMPLIFICATION
0 Members and 51 Guests are viewing this topic.
IWD
to Magluvin about the laptop
I was trying to solve almost same problem with XP instalation, If Nlite does not help you, then you do not have much possibility left.
some laptos have in bios a settings where you can specify how system acces the hdd, as raid or classic IDE of course for xp you must select IDE or some emluation if is there this option.
Otherwise you can just install windows vista or windows 7 and then downgrading it to XP http://www-307.ibm.com/pc/support/site.wss/vsta-dwngrd.html
(if you dont like windwos 7 or vista as I)
About electronic... I was already tried to charge cap from hv spikes form coil to value about 1500v and then discharge it to 12v source battery, of course I was playing with timing and with value of caps and manny other thing, as for example magneticaly quenched sparg gap, and also with diode.
I also tried cap charged to value about 500-600 volts and then discharge it to battery over mossfet with various timing independent to charging circuit. Also with another coil, and also with step-down transofrmer.
But no succes
DreamThinkBuild
[OffTopic]
Hi Magluvin,
Does the Hard drive show up in BIOS?
If it does try tapping F8 while the computer is booting to see if you can start in safe mode.
When my windows has PMS I use Slax(linux) a lightweight OS which I boot from a USB stick to access windows files. This will also mount the laptop hard drive if it is still accessible. Then you can dump important files to CD-ROM/USB stick before wiping.
http://www.slax.org/
If you can get access to a working system. It's very easy to install just unpack the tar file onto the usb stick run the bootinst.bat and it's good to go. Just make sure BIOS is set to boot from removable device on the laptop. It's a handy backup to have.
[/OffTopic]
wattsup
@Magluvin
If you can't get into the hard disk via the windows dos prompt, then you will have to remove the hard disk, install it as a secondary hard drive in another computer, then check your hard disk C drive root directory for the file "ntldr" without an extension. If this file is missing, you will not be able to open windows. Just copy the ntldr from the working computer root directory to yours and this will fix the problem. It has happened to me before.
wattsup
Doug1
Mags
Personally I am in the middle of building a Inbert down draft gasifier with a 30 gal hopper big enough to take full size fire wood. It will produce hot water and hot air if i get the calcs right the fuel to run a forge and even a i.c.e. generator for 12+ hours per load of wood. I cant see spending every second and every extra penny on ideas that may or may not work.I can see saving 400 a month to reinvest into the lofty ideas once I have an alternative to the expenses of heat hot water and a portion of my electric bill. The money that would have gone toward feeding the utillity companies will be well spent against them at they'er loss rather then mine. This tactic is what is used against all of us by the governing bodies and utillity companies.Such a system is not practical for everyone but the stratigy to save your income for use as you see fit instead of to pay a premium for all your comforts will get you there.
Yea yea Ive been taking pics will doc it ect.. once it is done.When energy goes up 2or300% it will be a lot more attractive even to those who think it is not what they want now.
Magluvin
Hey guys
I really appreciate all the help with the laptop problem. Didnt get a chance to mess with it yesterday. I have had a lack of sleep lately. Cant get to sleep til 3 n 4 am. Night before was past 5. Strange thing is, was waking up fresh. But last night, ate then slept.
I think maybe my Nero software didnt make the cd auto play. xp cd does auto play, so the machine is ok in that respect. If this nero dont work, I will try some of the ideas also.
I have a couple usb hd cases and 1 does fit the sata, the others are ide.  But the drive didnt work with it. It may be a special drive. I have had drives from particular machines that I wasnt able to use on other machines. For a good example, Xbox drives. No go.
One good thing is, others with this Alienware have had the identical prob.  So there is hope.  The one guy on the forum asked for help for a while, and had a lot of it. Once he finally got it, he didnt give the solution, never came back , and others inquired that they needed the solution. =[
Im persistent when it comes to these things, I will get it.
Thanks again  ;]
Mags
