ENERGY AMPLIFICATION
endlessoceans
Quote from: Jeg on February 21, 2017, 07:04:17 AM
Hi guys, Erfinder ;)
I'd like to ask, if the phase difference between current and voltage inside the "in series" circuit is one of the key points. It is something that hasn't been discussed yet and can make a whole lot of difference in predicting circuit's behavior.
Getting warmer
sm0ky2
I would say that if your tools operate by taking an average, sampled over time
This form of analysis becomes essential, to understand what is happening
Otherwise it is utterly redundant reverse engineering
Instead of an ionizer, we could use this to operate a low inductance motor
Powered by the energy normally wasted in the primary motor.
The "free energy" is the energy we throw away to avoid direct combat with Lenze.
If we didn't throw it away, the motor wouldn't turn, it would just be a heater with a
stationary rotor inside.
Tesla is showing us one (of many) methods to use this energy instead of throwing it away.
I'm not going to go back and forth arguing over what Tesla teaches us, and other people's
Imaginary concepts of magical events.
It's not that complicated
The technologies we have today do the same thing more efficiently, if you get lost on
the mundane details of a non conventional mechanism that's been obsolete for 8 decades
You are missing the context of the operations taking place by said mechanism.
The motor isn't there to provide the energy. It's there to provide an air flow and actuate the
rotary (commutator/or spark gap - it's irrelevant except for convenience).
The motor is the main inductive load, and from a perspective outside the circuit, is
consuming all of the energy. (Whether we use it or not)
The ionizer is operated with only a fraction of this, and the air flow can be achieved using
the ionic potential already present on the plates, therefore requires no fan.
Timer circuit or suitable transformer can run the Ion machine using a fraction of Teslas motor
set-up. And these units are commercially available today. The Ion machine is not important,
what Tesla is really showing us is that the motor doubles as an a/c signal generator.
There's nothing special going on here that Tesla did not demonstrate in his first oscillator.
That's what we should be paying attention to, His secrets are in how he uses the oscillations,
Not his tricks for creating them in a time when we didn't have the tech.
We have the tech now.
Just use a signal generator, a 5555 timer, a radio, a [insert circuit here]
Take the drawings and draw a big red circle around the primary and the capacitor
Take a black sharpie and destroy the rest of the image
Now focus on what is inside those two red circles.
What are they?
Why are they what they are?
How do they relate to each other?
What the f?  <---------------------
Build it
And all will become clear
partzman
Quote from: Erfinder on February 21, 2017, 02:37:37 PM
Phase relation is important, and not just in the "series" circuit.  Food for thought....  Reactive power is useless up until that moment when you realize it isn't.
I hate to be redundant but below is the sim from post #7952 only with some additions.  I have shown the reactive power levels in the series and parallel circuit producing the ozone.  They both  have negative power levels therefore their phase angles are slightly >90 degrees.  The motor powering the fan does not loose speed as it field maintains constant current so the ozone (or ideally any load) is produced for free IMO.  Energy amplification.
pm
luc2010
Hello,
tesla us patent 568 176:
i think its:
3 coils wound on toroid! + interrupter(to discharge the 2 caps)+ 2 caps in series + 1 tesla coil?
about the 3 coils? have one more question?
if we connect the primary coil in parallel with the secondery coil of tesla coils? what will happen?
not sure, but maybe we know the true LC circuit!!
Thanks and Regards
luc2010
shylo
I think Tesla figured out how to use the flow through circuits , to initiate flow in secondary circuits.
Never getting enough to be the primary , but enough to run secondaries, but you can add more secondaries
That in the end add up to more than the primary can produce.
If you bounce the magnetic field against a field that is of the right polarity at the right time,it can assist
instead of working against you.
It's like taking a little from each sub-circuit to add up to be more than the initial circuit is providing.
I may be wrong , but that is where I'm looking.
artv
