ENERGY AMPLIFICATION
0 Members and 188 Guests are viewing this topic.
leonelogb
Quote from: Tito L. Oracion on February 23, 2017, 01:44:20 AM
https://www.youtube.com/watch?v=GtnZc1dujgg
https://www.youtube.com/watch?v=y97rBdSYbkg
https://www.youtube.com/watch?v=8yYWILv91YU
https://www.youtube.com/watch?v=HMc3fvm7m7s
see tesla is right it can go millions of horse power :o :)
momentum, chain reaction and accumulation.
What does mean these words?
Momentum= High volt?
Chain reaction= Primary and secondary together like pic under..?
Accumulation= Is in self-induction? or bifilar-coil capacitor? or Regular capacitor? ???
Magluvin
What you are prescribing as an analogy to energy amplification is just an illusion. Magic trick. balony.
If it were a good analogy of EA, then by tipping the smallest block, it would lift the next larger block up from a fallen position to a standing position. In those examples, the blocks are already loaded. The energy was put into the system by standing the blocks up and the smaller blocks are  able to topple the next block because the next block is capable of being set off balance easily.
More detail.... What you are showing in those vids would be similar to having say 5 capacitors, each one larger than the next, say 2uf, 10uf, 50uf, 250uf and 1250uf as an example. Each cap would have to be precharged, just as the blocks would have to be stood up. Then each cap successively is able to trigger a switch, relay, transistor on the next larger cap to dump its charge into a load, or just short it out to drain the energy in each successively. All just a huge waste of energy, zero efficiency. ZERO.   You are misleading people in a completely opposite direction than what they are here for. Terrible.
Where is the EA in that? Again, false info given as if it would actually help us. Hasnt for 9 years or so no, so what more would we expect. Just more tricks and garbage.
Mags
Magluvin
Erfinder
What specific motor pat should I be looking at?
Or can I find 'what' in any of his patents?
Mags
endlessoceans
Quote from: Magluvin on February 24, 2017, 08:27:35 PM
If it were a good analogy of EA, then by tipping the smallest block, it would lift the next larger block up from a fallen position to a standing position. In those examples, the blocks are already loaded. The energy was put into the system by standing the blocks up !!!!
and garbage.
Mags
PRECISELY
Kinetic energy.  Finally someone seeing the light here.  Anyone can roll a big stone to the top of a hill and then with a push of a little finger watch that stone roll down the hill again causing massive destruction......but the stone doesn't magically run back up the hill on its own again does it!!!  That would be overunity.
Tito is a bloody idiot halfwit retarded child.  Why keep asking somebody who doesn't know for the solution????  That's even dumber than tito himself
Hey Tito do you still go to church and pray for forgiveness after lying to yourself and others each week???? ;D ;D ;D ;D ;D ;D ;D ;D ;D   All of your stupid youtube of known scam does not make it the truth.
