ENERGY AMPLIFICATION
citfta
Quote from: endlessoceans on February 25, 2017, 07:03:40 PM
Heard that before too
You aren sorry...just mentally ill
What a lame brain you are!  You claim you want him gone but then you deliberately write stuff to provoke him into making a response.  If you really had any sense you would just let him go without all the drama.
You can write all the silly crap you want to about this post but I will only ignore you.
that_prophet
GEM Geometrical Electricity Multiplication
Re: GEM=(Geometrical Electricity Multiplication)
http://free-energy.yolasite.com/
« Reply #100 on: Today at 12:50:57 PM »
   This technology is truly very simple, as it uses the circumference difference of one large pulley of 100 cm, and many,(10) small 1 cm circumference pulleys. By using multiple smaller pulleys we can multiply the total # of rotations, and by adding AC generators, we can multiply our AC cycles of electricity. It is as simple as that, you are using the use of multiple pulleys to multiply your total # of rotations, which can be turned into AC electricity, by simply adding AC generators to the many, 10 small pulleys.
   You are taking the 100 cm of belt that you get from the one rotation of a 100 cm circumference pulley, which costs only the slight amount of electricity that it takes to rotate a DC motor once.  This is called a GEM = Geometrical Electricity Multiplier because that is what it does, by using multiple # of small 1 cm circumference pulleys, with AC generators attached. So you only pay for one rotation of a large 100 cm circumference pulley, and get back a multiple of 100 rotations, for every 1 cm circumference pulley with an AC generator that you attach to the same belt. So, if you add ten small 1 cm circumference pulleys, then you would get a return of 1000 cycles of AC electricity, all for the cost of one rotation of your DC drive motor. You just have to be multiplying you electricity, gaining 1000's of cycles of AC electricity, for the cost of the slight amount of DC electricity that it costs for one single rotation of your DC motor.
   This mechanism should run perpetually, with the 1000's of cycles of AC, when run through bridge rectifiers, should easily be able to produce enough DC electricity to crank your DC motor over once. These 10 AC generators would be easy to rotate, as they are just being used to wind up massive voltage, and only need to have the slight amount of current that a DC motor takes to rotate one single time. Since torque is caused when you are generating power, and power is current times voltage, P=IV. Since we only need the smallest amount of current, practically zero, and zero times even massive amounts of voltage still equals practically zero. Thereby these small pulleys should rotate with practically zero torque, and they should be winding up massive voltage, which is exactly what you need  to crank the DC motor over just the once.
     Just build this super simple GEM - AC electricity multiplying device, and watch it work. Once built, you should be able to start it running by simply giving the large pulley a slight rotation. These AC + DC motor/generators should run continuously, allowing you to tap electricity off of both your AC + DC generators/motors. If you find that this GEM free energy device does not have enough DC electricity to power your apparatus, then just add more 1 cm circumference pulleys with AC generators attached, to the same belt, to add additional current + voltage capability.
YOU ARE PAYING FOR 1 ROTATION + GETTING BACK 100's,,, OR 1000's,,, OR MORE
by simply using pulley mechanics, you can multiply your AC electricity cycles.
what I happen to be doing, is using simple pulley mechanics,
to change 1 rotation of a large 100 cm circumference pulley,
into 100 rotations of every 1 cm circumference pulley that you add,
+ thereby multiplying the total amount of AC electricity.
By simply adding a belt to connect these two or more pulleys,
and by simply adding 10 of the 1 cm pulleys with AC generators,
you can gain 1000 cycles of AC electricity,,, all for one small amount of DC electricity.
   I originally added a battery into the system, to store the excess power, and added a warning to this mechanism that left alone, this battery charging device could result in the battery exploding + catching fire. I worried about this, because of it being able to continuously produce power, and overcharging the battery. I stated that you needed to have a cut off circuit, to prevent over charging.
This truly works guys + gals,,, I know that it sounds too simple to actually work. You are using simple pulley mechanics to multiply your total # of rotations, and by simply adding many small pulleys with AC generators attached, you could be using pulleys to greatly multiplying your AC electricity, instead of paying money to the terrorist for oil.
It is the billions of evil spirits that are screaming in your ears, "THIS WILL NEVER WORK" + "ONLY A FOOL WOULD TRY THIS". That is because they are desperately trying to hide this ancient UFO technology that can be found in the Bible = Ezekiel 1:16. They are + have been hiding this super grade school technology because they want us to keep buying oil,,, from countries that produce terrorist,,, to help create terrorism = what they like best
<<< EVil-sOLUTION >>> (isn't it amazing what is revealed by the il-s of life)
http://decimationofthisevolutionfairytale.yolasite.com/
THIS IS GOD'S GIFT TO THE SOON COMING TRIBULATION SAINTS
Because the Door will close on this Prophecy being fulfilled on Jan 15th , 2019
http://doorschristmustpassthrough.yolasite.com/, http://2020-vision.yolasite.com/
These are the rules God has set before us
http://beliefstoliveby.yolasite.com/
possible timing for TRIBULATION SAINTS
http://possibletimingfortribulation.yolasite.com/
UFOs + GHOSTS do exist, there are just not who they pretend to be
http://aliensandghosts.yolasite.com/
It was how God predicted, to the exact day,,, May 14th, 1948
the day that Israel would get their second chance + become a nation again
Written in the Holy Bible way back in Ezekiel's day
http://www.grantjeffrey.com/pdf/JeffBIBLE-EzekVision2.pdf
This convinced me that the Holy Bible spoke Truth
About Jesus Christ paying for our Salvation
+ Jesus being the only Door for us to enter Heaven
Becoming one part of God's Family
citfta
You have been asked several times to stop polluting other peoples thread with your foolish ideas.  Since you refuse to honor that polite request you have been reported to the Admin.
If you insist on posting over and over again your false ideas you should at least have enough respect for others to restrict your posting to one or two threads and not pollute the whole forum with your false prophet ideas.
You have one person who is trying to prove your idea.  Go work with him and leave the rest of us alone.
Carroll
shylo
Is heat not a form of energy?
Or better yet , the disappation?
Utilize it all.
artv
shylo
Heat is created when the flow is being impeded , correct?
All motive action creates heat, ?
Heat can generate.
Tie them altogther and it might work.
artv
