ENERGY AMPLIFICATION
that_prophet
this GEM technology has everything to do with this subject,
I use pulleys to multiply AC electricity,
.      This GEM = (Geometrical Electricity Multiplication) technology is super simple, http://free-energy.yolasite.com/ and is based on basic pulley mechanics. In it, you pay a small amount of DC electricity to rotate a large 100 cm circumference pulley one single time, (one mere spark). Then you run the 100 cm of moving belt, (off the 100 cm of circumference) past a mini-pulley of only one centimeter circumference, giving you 100 rotations, which you covert into 100 cycles of AC electricity, by simply adding an AC generator to it. You are merely using the 100 cm of belt that you get off the single rotation of a 100 cm circumference + by running this length of belt by a 1 cm circumference pulley, with an AC generator attached.
.     Now, you have just multiplied your single burst of DC current into 100 cycles of AC electricity. Please don't listen to the mythical torque problem, because there is no torque problem. This AC generator is running practically torque free, because all that it has to generate is the single burst of DC current that your DC drive motor takes to make one rotation. And please remember, that you get 100 cycles of AC electricity to generate this single "spark" of DC current to power your drive motor, so this is generating practically zero current, divided by 100.
.     If you run wires from your AC generator output, + put them into the input of a full wave bridge rectifier,(4 diodes) + then run wires from the DC output of your full wave bridge rectifier, into the input of your DC drive motor, you should have a working mechanism. This perpetual free energy generator mechanism is complete, + you should be able to start it running by merely rotating the large pulley by hand, a quarter turn.
.     You must have your AC generator + your DC drive motor of the same voltage.
.     This is so simple + cheap to build guys + gals, please build one to prove it works,,,
I live in a nursing home, so I cannot even have the simple tools to build this with. This is so dirt simple + easy to build, that satan is laughing his as? Off, at how gullible we simple humans are. But he will get his just deserts, when Jesus returns in His Glory, before the second door close on 2025.94 = 2019.04(door for rapture) + 6.9(7 Hebrew years = 2520 days) http://doorschristmustpassthrough.yolasite.com/
Quote from: Erfinder on May 25, 2017, 05:43:19 AM
that_prophet,
delete your post, it has absolutely nothing to do with the subject.
blueplanet
Quote from: that_prophet on June 18, 2017, 06:18:16 AM
You are saying the DC spark can be make a difference in terms of the torque produced by the AC generator. Do you have any idea how to create this DC spark without consumption of too much energy?
I presume one spark is not enough. Do we need to fire a number of this spark periodically to sustain the energy supply?
v8karlo
TITO! , I have question for you if you can help. I don't wanna know how your device is working. My question is about something else.
Your device magnify power. So when you feedback in next cycle you get more and more. In number of cycles it will grow sky high and fry everything. How did you prevent it from going disaster high?
Zener is ok for smaller values. Spark gap maybe, but the output then will flicker alot!
I cannot find any good solution, so can you help me?
Please no riddles! If you know answer and can help just do it!
Thanks!
forest
I don't have the solution you need ...but I know some old guys were using a mass of iron to control the feedback. When the iron mass saturate it will change the characteristic of device and limit the output to almost zero. Today it will maybe need a better core...For air core there is a problem.
I think that even large electric generators are using this trick indirectly (because we still believe they convert one form of energy into another  :o [size=78%])[/size]
