ENERGY AMPLIFICATION
0 Members and 56 Guests are viewing this topic.
forest
Remember what I posted about water pressure on hole at the bottom of container. It may be that the missing puzzle is the floating piston above. Its weight will add to the pressure of water column and make more spin on generator turbine.Generator is powering the pump which recycles water back to upper container. The secon missing puzzle is how to build such piston which must be heavy and still floating on water surface.
Here is a tricky way  ;D
Make a piston empty with a hole on bottom and a valve, make additional tube through the piston not in contain with empty area inside but protruding directly to the bottom and second hole and second valve.
Valves need to be electrically or mechanically opened/closed.
I would try to draw schematic and explain how it works.
forest
Hmm..quite complicated but it may work.
A1,A2,A3 are electrical valves. B is a valve which allow only air to escape not water.
C is a  support released by electrical impulse.
Oh boy oh boy oh boy. How can a thread get this long with little to no progress. And ironically the ones who try to make progress get shot down.
Tito, people like you are dangerous on the Internet, you need serious psychological help because you have some serious disorder which you are only making worse with every post. Your attention seeking narcissistic personality disorder should be treated by a professional.
The bad thing about the Internet is that everyone can use it, people with some serious issues or a traumatic past get the chance to project their issues online in all kind of strange forms. It takes simple common sense to see this in this thread.
forest
Continuation...
1.Initial stage : piston is filled with water, all valves are closed ,upper container is filled with water from A3 up to C.
2. C is released and A3 is opened. Water flow by own gravity and piston weight pressure.
3. Water is flowing through A3 valve turning turbine which generate electric current powering water pump . Water is pumped above piston ; piston weight is bigger and bigger in time, water pressure is almost not changing (compare it to the gravity only when water pressure on valve depends on water level above)
4.When piston touches bottom of upper container A2 valve is opened and water from inside of the piston is escaping.Then A2 and A3 are closed and water flows through then hole across piston and fills the space below piston (which now empty) pressing piston up.
This schematic need a lot of improvements to convert most of valves to mechanical devices eliminating as much electric energy usage as possible.Anyway,it's just a theoretical schematic.
Tito L. Oracion
Quote from: broli on February 11, 2011, 10:10:04 AM
hi bro  ;D
The way i see your comment i think it is you who need psychological help.
you reading capability is not enough man! mags continue his work in other thread, is that ok now to you good reader?!
Yes! it takes simple common sense if sense is common to you brilliant reader!
i'm not seeking attention here, i just shared a little info! got it?, best reader?, huh!
You know what? a person can be know if he is intelligent or nothing, the way he talk and make his words if they are sensible or not!.
One more thing bro! You need to eat more BROCOLI for your eyesight. ;D
