ENERGY AMPLIFICATION
0 Members and 40 Guests are viewing this topic.
Most of us know the history from the calculator machine and the micronizing during the last decades.From room- wide mechanic "kolossos" to EPROM( software included) small devices.Bit/ Bytes processing from Hz- range to KHz, MHz, GHz,THz to PetaHz.One Hertzianische "Schwingung/Kreislauf/ cycle" stimulated by to 2 Pulses per second, ergo 50 Hz~ 3000 RPM,US 60 Hz~ 3600 RPM.
Let us look for power density maximizing :
http://electrifyingtimes.com/Helmut_Schiller_motor.html
For a 3000 RPM motor( or generator)for a 1 KW output we need 0,5 Kg Material and circa 0,5 Kg for the case (UQM- number).Let us maximize the RPM and by each step halving the weight : to 6000 - 12000 - 24000 - 48000 - 96000 - 192000 - and finally 384000 Revolutions Per Minute so we have a weight reduction from 1Kg- 0,5 Kg -0,25 Kg-0,125 Kg-0,0625 Kg- 0,03125 Kg to finally 0,015625 Kg total material need for an 1 KW revolving machine.fiftheen virgula six two five Grams for 1 KW kinetic or electrical output( without conventional losses incorporation)-----------------------Why 384000 RPM ? Cause this number is near the (60O)v2 RPM = 360000 RPM Kunel- gear :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=13&ND=3&adjacent=true&locale=en_EP&FT=D&date=19771103&CC=DE&NR=2617553A1&KC=A1#
-------Are  360000 RPM much ? In quantummechanical FREQUENCY- turns( static velocity) this is a ridiculous low number :
6000 Hz or 6 KHz per second.-------                       hydrolysis frequency spectrum
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=6&ND=3&adjacent=true&locale=en_EP&FT=D&date=19940505&CC=DE&NR=4238952A1&KC=A1#7,3 x (10)v12 Hz work process frequency;
                       induction heating frequency spectrum
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=7&ND=3&adjacent=true&locale=en_EP&FT=D&date=20161222&CC=DE&NR=112014006403A5&KC=A5#
50 Hz up to 50 KHz induction heat process frequency-----------------------
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=20140213&CC=US&NR=2014043128A1&KC=A1#708 ccm device volume and Frequency process velocity dependant output?! 400 Hz work range : 16,78 KVA and 6 KHz work range : 256 KVA output
Very low cost hydrolysis,  also useful for syn-/waterfuels production------------------------------------------
From molecular co-/ adhaesion force range to nanoquantummechanical = nuclear force range,  using temperature- neutral magnetic current ( more : Prof.  Ehrenhaft)
electro-magnetic spectrum,temperature- free Infrared-waves---------------------
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=6259347B1&KC=B1&FT=D&ND=3&date=20010710&DB=EPODOC&locale=en_EP#"IT IS NOT GENERALLY RECOGNIZED... IS INCREASED"
This last is from the US Navy R&D, if I include Harold Goldbaums generator with these east- german device
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19891018&CC=DD&NR=272727A1&KC=A1#
we will get a mass destructive weapon or a mass destructive industrial device . An electro-magnetic beam in  Tera-Watt- range. On a Drone ...-----------------Probably the in the 80' patent applied east german decelerator device comparable with https://worldwide.espacenet.com/publicationDetails/description?CC=WO&NR=2015164531A1&KC=A1&FT=D&ND=4&date=20151029&DB=EPODOC&locale=en_EP#
partzman
Quote from: leonelogb on December 21, 2018, 08:47:37 PM
Bob, I think that you and I,  have been looking for the same thing... The real power... IRON WIRE(TAKEN FROM THE EDDY CURRENT) I have some file that confirm that this energy is 10,000 (permeability)times more out that which we put in. That pdf. It was written by Cyril Smith(Smudge). And I have other like patent that confirm; power coming out from iron wire. PM me if you want make deal or if rather by this way, Not a problem for me  ;D ;D ;D Just suppression like D45  :o :o :o  8)
Thank you MASTER Tito L. O.
For the record, the snippet you show is from a paper by Cyril entitled "Magnetic Energy in Ferromagnetic Material 4th draft ©Cyril Smith, November 2003".  I have attached the paper below for reference.
Cyril is a wealth of information regarding theoretical physics and how it would/could apply to potential free energy devices.  As an individual, he freely contributes more in this area than the sum total of any and all individuals I can think of! My hat is off to this man and he is deserving of way more credit and respect than he is given.
Regards,
Pm
leonelogb
Partzman
Me too, My hat is off to this man, I wish that he come over and teach us the best way to use this kind of machine (with iron wire).
Tesla in his 77 year old said something about it, but we know that Cyril Smith can help us. I know that ramset is a good guy and he has been working hard to do this world better, He can contacted him. Peace!
Quote from: partzman on December 22, 2018, 02:20:27 PM
Regards,
Pm
thinking reversible-
Photo-n-electric
L.E.D. Light Emitting Diode and  L.A.D. Light Absorving Diode-
Phono-n-electric
M.E.D.   Magnetism Emitting Diode and M.A.D.   Magnetism Absorving Diode-
Why high frequencies ?
https://en.m.wikipedia.org/wiki/Triode
"Transit Time"/ gap distance
"recombination" time window
Belfior
Well light and electricity are the same vibration, just different frequency. I have been trying to say to people, that freq must affect the power somehow. I get told "no", because some equation is missing freq as a parameter.
Do you blue laser has more power, because it has more light in it? It has more power because of the higher freq.
Every transformer is an OU device. The L2 gets its power from the ambient by excitation that the L1 provides. The brainfart there is the return line to the grid on L1. You immediately owe that and you gotta pull major magic to compensate for it. Just use DC pulses and a coilcap. Then you use just fields
Then the core. Is it anything else than induction? Well why are we using just one core loop then between L1 and L2? Too much gain?
Does the electricity get spent, if it passes the L2? I am pretty sure you can light a bulb if you place it after L1 in the coil cable. Well why no pass it through 100 cores then?
If the core is just a "coil" and the transformer is just induction, why not make our air core L2 coils thick copper pipe that is self looped with a cap for resonance? Then cover the L2 with with insulated cable that is then the ouutput.
If static charge can charge caps, why not use a bicycle wheel that has "pads" that get charged from an "eternal battery" meaning the static charge holder? Wheel would turn and charge a pad. Then the wheel turns and you dump that pad to a cap. I bet the static charger would hold its charge in vacuum for weeks.
What if I put an open coil around a core, then a diode and a cap. Another open coil with reversed diode over the core and to the other side of the cap. Cap plates are connected by L1 that has a spark gap and induction to L2. You tell me how Lentz comes into play, when it can't get through to the source because of the ipen coils.
My point here is that we need to rethink everything from start to finish. If free energy exists, that automatically means that active suppression exists too. It is in the school books, science and engineering. This is guaranteed by the 5 trillion they make every year selling electricity to us. They know that some day the game is over and that is why the electric bill says kWh. They only rent it to us by the hour.
I have under a hundred more ideas and I was going to use them for different patents and getting me money. I have come to a conclusion, that this is the only reason we are still slaves. I will test all my ideas, since for sure most of them are just wishful thinking. The rest I will publish open source, because we are 100 years behind our evolution all ready.
Merry Horus' birthday to all!
