ENERGY AMPLIFICATION
0 Members and 60 Guests are viewing this topic.
Bob Smith
Quote from: e2matrix on November 21, 2019, 04:34:51 PM
Bob,  it's just a matter of dragging the short wire between the ground (upper half) and the circuit to right - grab the area closest to the circuit and move it so it's straight up thus connecting it to the circuit.   The drawing is a bit misleading in that it looks like the switch arm is already in contact with the circuit but it is not until you point it straight up.
Interesting how it takes off very quickly to show giga volts and giga amps.   transformer appears to be a 100:1 ratio.   Looks easy enough to build but would it really start achieving high power like that?   It would certainly need some limit control or it would immediately fry everything.    ;)
Thanks e2
That was unbelievable. I thought for a second my computer was going to blow up!! LOL
What do you folks think is happening?
It looks to me like the charge from the ground is feeding back into the circuit, driving it to multiple harmonic levels.
I actually think this is directly related to the Barbosa-Leal apparatus.
Bob
Raycathode
The circuit that's puzzling you is in complete and don't you think you might be putting too much faith into so-called computer emulation thats programer controlled.
note B is also a switch.
rakarskiy
Quote from: Raycathode on November 22, 2019, 12:51:00 AM
No way, I have no illusions. Firstly, the parameters of the voltage potential, shared by the simulator, are simply not real for the incarnations (capacitance, cross-section, etc.). If you wait a long time, the circuit is discharged. This suggests that there is a reason for the excitation of such a potential.
http://tinyurl.com/vlvbvk5
Option with antenna. The software in the antenna does not have high potential. Where does the potential in the chain come from? it's just a toy for touch. can be assumed. that the error of the algorithm, or the resonant effect.
http://tinyurl.com/yx5kabgn
In this embodiment, the circuit just explodes
rakarskiy
I understood why the simulator was counting cosmic results. The bug is fixed and the scheme works closer to reality. The reason was the transformation rate of 99.99% . I put 0.9 and already the scheme works closer to reality. But it is worth thinking about how you can make such a transformer to get an explosion of energy.
http://tinyurl.com/qqkpfrb
A little bit analyzed scheme, changed parameters and received here is such outcome. The transformation ratio of 0.5
http://tinyurl.com/slurvpk
http://tinyurl.com/qp8gudw
Raycathode
Quote from: rakarskiy on November 22, 2019, 08:48:36 AM
Pardon my curiosity here but is this based on an aerial placed in the jet stream? err wouldn't you require some sort of metallic coated, possibly an army surplus barrage balloon of sorts for this idea, I'm not sure Tesla was thinking it this way  ;) :D ;D
https://www.indiegogo.com/projects/cloud-power-clean-water-and-energy-from-clouds#/
