ENERGY AMPLIFICATION
0 Members and 27 Guests are viewing this topic.
Belfior
Quote from: rakarskiy on November 22, 2019, 08:48:36 AM
I understood why the simulator was counting cosmic results. The bug is fixed and the scheme works closer to reality. The reason was the transformation rate of 99.99% . I put 0.9 and already the scheme works closer to reality. But it is worth thinking about how you can make such a transformer to get an explosion of energy.
http://tinyurl.com/qqkpfrb
A little bit analyzed scheme, changed parameters and received here is such outcome. The transformation ratio of 0.5
http://tinyurl.com/slurvpk
http://tinyurl.com/qp8gudw
That javascript "simulator" is fine when doing small experiments just to see if your idea works at all. For any "real" emulation you need something like LTSpice and proper modules. Even with LTSpice you   to do your experiment on the bench, if you are examining some anomaly. Using simulators is a good way to save on parts.
This one guy uses that javascript simulator to prove overunity and I think he just uses a bug in it. Battery or PSU is not even connected and he measures overunity.
rakarskiy
Quote from: Belfior on November 23, 2019, 06:01:58 AM
you're right, I use the simulator to test the circuits. Give the correct data for the calculation, the simulator will calculate them very close to reality.  The error was found, but not in the operation of the scheme, and the input parameters for the calculation. Efficiency = 0.9999 transmission transformer can not be. The error is fixed and the scheme works and runs logically. But we should not forget that now the question here is what you need capacitors? To bring this circuit into working form, capacitors are required capable of passing current without loss. Well, the capacitor with the antenna, probably a single element in the form of a capacitive dome. The most interesting thing is that this scheme works without a spark gap
You can restart or disconnect the antenna or ground yourself.
Atmospheric electricity has been used before, quite recently. Bloodsuckers shut for us this knowledge. Today, many researchers have come to believe that ancient churches with domes and other structures of this type, generate (or capture) atmospheric electricity. In this scheme, dispose of it in its pure form will not work but in the form of light or heat, it is even possible.
I came to the conclusion that the receiving capacitor and antenna is a single device. At once there were associations with researchers of domes of churches.
Mannix
That drawing looks like the Markovich device , interesting !
Moray alledgedly had something similar .
Keep playing ....who knows?
densama
hi .... where is magluvin hiding now ? ;D
https://patentauction.com/patent.php?nb=15323
Can somebody explain me/us what Mr.Dyba means with (P1 - P2)/P1*100  ?
