ENERGY AMPLIFICATION
nix85
Just few quotes..
"As the positive lines of force manifest results
through conductors, the negative currents and fields can only be
activated through non-conductors."
Contactee George Van Tassel
"The opposite terminal of the condenser being connected to ground,
which may be considered as a vast reservoir of negative electricity"
Tesla
Mark TPU only worked on one side, if flipped not.
Magluvin
Quote from: nix85 on June 11, 2020, 08:40:50 AM
Just few quotes..
Tesla
Havnt done anything with ground since my crystal radio days.   But the quote has me thinking.  Say we have just a plate of copper and then a ground post.  If we connect a cap to the gnd and the plat, will the cap charge?  Being the ground is said to be a vast reservoir of negative,  after a bit the plate may become positive and cap no longer charges. So discharging the cap would reset the plate charge and repeat.  Will try it as I have what I need to try
Mags
NickZ
  Maybe place a small flash light incandescent light bulb on the cap, or close by it to draw a small load that can keeps the cap from fully saturating, and stopping any further charges. Or two caps and a small bulb between them, as you were saying.
Magluvin
Was just a thought. Ive sort of neglected the ground for some time because I couldnt envision the full use beyond a crystal set. But, if we look at a crystal set, the coils usually seem of very thin wire, so not really a good carrier of currents we would want from it. I think.  But probably a thing to do would be to have different antennas for diff freq ranges and look for some potentially strong freq that may be useful and use a spectrum analyzer using those ant. Then make an LC for that freq with stuff that could carry higher currents than what we have seen.  Just thinking
Mags
Raycathode
Quote from: Magluvin on June 11, 2020, 06:28:06 PM
Mags
[/quote]On the EARTH section the cable from your ground cable needs to be tuned to same length as tank coil!
you will then get a powerful amplification. I found that out as a kid when I use to listen to European radio stations as that kid
it would drive a high impedance loud speaker, it was terrific.
Raymondo
