ENERGY AMPLIFICATION
0 Members and 89 Guests are viewing this topic.
nix85
Seeking hertzian waves is a blind alley. You ask if there is this etheric pressure, longitudinal waves from space, how come we don't detect them, what frequency all ask. Do you feel your own weight? Each nucleus of your body is resisting part of the spectrum of these vibrations that we call gravity. But there is much more than gravity. For example there is negative gravity at 1/3 higher frequency and opposite polarity (according to great Edgar Hollingshead, all my respect goes to him), there is vitality, there is magnetism, so much varieties of subtle etheric currents.
More on etheric atoms and currents. http://villesresearch.com/ether.html
There is a whole untapped world of neutral etheric currents, non hertzian apparently longitudinal waves. They seem to be pulsed DC or have a strong pulsed DC component. Frequencies don't have to be high, we know TPU worked around 5KHz and James Schwartz said he uses 5 frequencies based on Schuman resonance, probably harmonics, but he is not to be trusted, he lied about "72-73 elements" in those "neutrino rods" just so people would not understand how simple it was!
https://www.youtube.com/watch?v=MsJwRznsf4o
Those plates are bismuth and aluminum if i remember correctly and thin wire coils inbetween.
PS I corresponded with Schwartz, i first asked him really nicely to tell me how to make those rods. You probably guessed, no reply.
Then i wrote again telling him what a thief he is, then his hurt ego responded, but of course he revealed nothing.
nix85
I propose that so called cold electricity is part of the spectrum of negative gravity.
Energy from the sun comes mostly as positive neutral, nonpolarized energy, electrons if you will. How can it be both positive and neutral you ask, neutral simply denotes non hertzian waves which would show as circles on oscilloscope instead of sinewaves, but these waves can also be positive and negative, positive ones come from our male sun, and our female earth reflects back the opposite.
Positive manifest
LIGHT
HEAT
WEIGHT
Negative (reflected) manifests
DARK (as substantial as light with it's own 7 "colors" of darkness)
COLD
LEVITATION
..but upon hitting the magnetic field and top layers of the atmosphere these electrons or bubbles or neutral energy merge with similar ones and produce polarized aka hertzian waves we perceive as light and heat, but most of the energy does not get converted and part of the spectrum of that neutral energy we feel as gravity.
Magluvin
Tried an AV plug, well a couple with different size caps. Depending on the ant, of different lengths, got up to 9v.  22uf took a bit of time to charge. 1uf was much quicker and a .1uf seemed to charge almost instantly.  So could probably get more with more experimentation. But so far a small solar cell does much better.
Mags
nix85
nix85
I mentioned on some other thread how some guy in Eric Dollard's lecture from late 90s i think on youtube asked the audience to ask themselves how no flux cuts transformer secondary, yet voltage is induced.
This model with etheric smoke rings and magnetic field just an axis of the ring would explain that beautifully!
http://freenrg.info/Physics/Scalar_Vector_Pot_And_Rick_Andersen/Rick_Andersen_Ortho.html
