ENERGY AMPLIFICATION
0 Members and 78 Guests are viewing this topic.
Bob Smith
Hi Teets
Black Hole. Cool. What comes to mind is the "off" part of a duty cycle involving a unidirectional impulse. It's in the "off" time where the aether/ambient pushes back against the abrupt discharge spike with a burst of charge, seeking to restore equilibrium.
A few researchers have shown that this ambient push-back charge can be best collected from the center of a coil by a perpendicular (orthogonal) wire or coil. Remember Tito's occasional reference to the K-caps? (I think that's what they were called) - I think this is the same principle.
There are others who claim the mid point of a cylinder coil is the best place for collecting this charge - JB was a proponent of this "bloch wall" ambient charging effect. I believe he considered it to be a gravity wave pushing back at the bloch wall (not the right term, but everyone understands what is meant) after an abrupt discharge into the coil.
God bless you, Teets.
Be well bro.
Bob
Jeg
Quote from: Tito L. Oracion on November 17, 2013, 07:35:35 AM
let say for example I collected a stainless steel, alluminum, tin, copper, zinc then by the use of a grinder, i pulvorice them all mix them together.
then i have two option to combine them ist by epoxy, second i can super heat them using acetylene and oxygen in a mold
now the resulted material should be producing a little heat cause they are different metal joint together, then before i use it i introduce 2kv in it.
then i include it in a circuit capable of producing high voltage. what do you think is the result? ::)
Hi Tito ;)
I read back your writings and you have really left behind a ton of technical knowledge which is a treasure.
Between many things i found your above statement which is a great solution for self supported experimenters who can not afford the expensive ferrite cores.
Just two questions.
1. Why are you heating this material mix?
2. Is there any specific mixing analogy that you can suggest? (Like x-grams of alum, z-grams of tin e.t.c)
Thanks
Jeg
AlienGrey
Jeg, sorry to stick my nose in here, but perhaps I can help a little, I was looking at the 'YOU KU' website 'Color' originally posted
an interest in and again your self and others.
I'm not too sure how it works if it does as it's ferrox setup looks just like any other transformer, but it does look like it gets hot :o
hence the vent PCB strips around the device and it does appear to have 2 rather large lead acid battery's on the left of the device
however one would have to make tests and there is the uncanny resemblance to the Ruslan device ie the yoke core winding and
the air core of the Delomorto air core.
It would be interesting to know what others have found, and why do you think the ferrox cores are expensive ? you can get a pair
of cores for about 5 euro's
AG
Tito L. Oracion
Quote from: Jeg on July 18, 2020, 06:11:22 AM
Hi Tito ;)
I read back your writings and you have really lefth behind a ton of technical knowledge which is a treasure.
Just two questions.
Thanks
Jeg
Hig jeg, good day! :)
Its really just an experiment in my head at that time cause i'm reading a lot of
Experiment from different books so i just made think of that.
Its just a feeling in me that if i combine different metal into one metal, it could produce
An amp and a volt, and by introducing high volt is like reconditioning it and setting its capacity into that volt.
The experiment is like a battery combining different metals into one making them all shorted each other in the mix, and i'm expecting it to produce lot of power if i include in a
Circuit. Well, i did not do that cause i'm always looking for the best, i don't have time for very hard experiment , i'm always looking for simple one.
If you have time well, you can experiment on that but be careful cause i don't know the result either lol :D , sometimes by accident you can make something that you don't expect.
Like what tesla did about the apparatus that create an eathquake :D .
Anyway just be careful and God bless ;)
Let me lead you bro. :)
Make a research on how can you make an accumulation
About volt and ampere.
Tesla already told us about 10 watts of power in condenser into 18 million horse power
And that is very over overunity lol. ;D
Bye happy experimenting.
Try reviewing this one:
http://www.tfcbooks.com/tesla/nt_on_ac.htm#005
Efren ;D
Jeg
Quote from: AlienGrey on July 18, 2020, 06:42:01 AM
AG
AG
Thanks for the input my friend, I watched it very carefully and i am sure the Chinese man is doing at the side of the yoke core what Ruslan is doing at the end coil. I am looking for cheap cores for the end coil (like grenade) and not for the yoke push pull. I have used recently a bunch of small toroid cores but if you see Tito's suggestion i think it is very interesting.
About delamorto's circuit it looks genuine. Especially C3 which only charges and never discharges is a new way of making a virtual ground with only positives. If you like to discuss it more we can do it at the Dally-Kapa thread.
Tito.
Thanks for the quick answer. I have read your posts carefully for more than ten times!!! :D
You are a real inventor my friend and your advises are not for starters.
A core that consists of all those metals that you described is very interesting and i like to experiment on this. I think it will also work without pre-charging. If i manage to construct it i'll post some results.
Best regards
Jeg
