ENERGY AMPLIFICATION
0 Members and 74 Guests are viewing this topic.
Quote from: WhatIsIt on July 23, 2020, 07:56:01 AM
Too much money was at stake, so faking is less probable.
Nix,
Random numbers are random and we can not predict sequence.
But dividing numbers will give sequences which we can predict,
because the result is always the same.
There is simple way to solve entropy.
2 small numbers divided can give up to 10 numbers before they start to repeat.
22/7 = 3.142857  with 2 small numbers which can be packed into 1 byte,
we wrote 7 numbers.
Which gives me idea.
Irrational numbers.
Pi is holding all combinations in universe never repeating.
Question is how to implement pointer to known sequence inside it?
Another example is square root from 2,
same thing.
It holds all possible short and long sequences needed.
Are you in the right topic ?  ::)
                               TRANSZENDENZ
e= 2,7....
pi=3,14....
log
Not only Pi(number not confound with Puls)  for cycling is in EE important but also e for EE-designer :
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=nicholas+Christofilos&CPC=&IC=&Submit=Search
https://www.google.com/search?rlz=1C1AVFC_enPT797PT797&ei=iHwZX67JMonolwSlnom4Ag&q=christofilos+effect&oq=christofilos&gs_lcp=CgZwc3ktYWIQARgAMgQIABATMgQILhATMggIABAFEB4QEzIICAAQBRAeEBMyCAgAEAUQHhATMggIABAFEB4QEzIICAAQBRAeEBMyCAgAEAUQHhATMggIABAFEB4QEzIICAAQBRAeEBM6BggAEA0QHjoHCCEQChCgAToCCAA6AgguOgUILhCTAjoECAAQCjoGCAAQChATOgYIABAeEBNQ3VBYzIQBYJuSAWgBcAB4A4ABigGIAboYkgEEOC4yMZgBAKABAaoBB2d3cy13aXqwAQDAAQE&sclient=psy-ab
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=62&ND=3&adjacent=true&locale=en_EP&FT=D&date=19871119&CC=DE&NR=8711619U1&KC=U1
[0063] A eine Vorrichtung zur Erzeugung von elektromagnetischen Impulsen (EMP) zu schaffen, die die gleichen physikalischen Eigenschaften der elektromagnetischen Impulse (EMP) haben sollen wie die, die nach einer nuklearen Explosion in der oberen | Erdatmosphäre entstehen.
[0064] Diese Aufgabe ist durch die im Kennzeichen des Hauptanspruches angeführten Merkmale gelöst. Die danach erzeugten elektromagnetischen Impulse (EMP) bestehen aus zwei elektrischen Komponenten
[0065]  Die erste Komponente bildet den elektrischen Compton-Strom, der nach dem bekannten Compton-Effekt bei nuklearen Explosionen entsteht.
Bei der zweiten, in der Literatur unbekannte Komponente handelt es sich um einen elektrischen Strom bzw. ein elektrisches Feld, das durch die Oszillation eines monopolaren Hybridplasmas entsteht. Beiden Komponenten stellen voneinander unterschiedliche impulsartige Wellen dar, die
[0066] I simultan in Superposition verlaufen. In Gleichung I sind die[0067] zwei Komponenten mathematisch dargestellt:
[0068] EMP = Pc + Pi
[0069] worin
[0070] Pc = Compton-Strom-Komponente
           Pi = monopolare Hybridplasma-Strom-Komponente bedeuten.
WhatIsIt
Wrong topic.
Thanks Lanca.
Magluvin
To continue....
Wouldnt it seem logical if as we add single turns in parallel on the toroid core, that the inductance should increase each time we say, double the number of turns? All in parallel.
The reason I am pondering it is Tesla, as I said earlier, said large inductance, low resistance.  So Im going to try it and see.
Imagine if as we add more turns, the resistance goes lower and the inductance goes higher. Not something we are used to.
When we say inductors in parallel decrease the total inductance, that is, if I am not mistaken, individual inductances that are not magnetically affecting each other.
But if all on a closed core, and mutual inductance between windings occurs, then we might have something different than what may be typically calculated as a standard for this exercise.
The more we get the resistance down and the inductance up, then resonance would be a much more useful thing. ;D
Mags
Leely
Quote from: Tito L. Oracion on July 22, 2020, 01:22:30 AM
I've been so very stubborn here for many years and been acting
As a very bad person, i even see someone wants me dead,
Even they push me to go out a here always i kept on comming.
Sorry about that. :(
But to tell you the truth, if you only can see my heart , brain and eyes are
Really in tears currently believe it or not, i considered everyone in here as my brother or friends
Especially the atheist, i don't really know why they can't see God and i can,
Whats wrong really with their eyes or my eyes why? why? why? :( :-\
I kept on inserting and inserting what i believe is truth,
Making always debate on them not that i don't like them but
Simply because i love them all and that is really what is in my heart everyone. :) :'(
Because i know God will hurt them eternally and i don't want that
To happen honestly :( :'(
To Anyone, i am not angry to all of you ok.
There is reason to everything.
Finally i think this is now really my point of no return. :) :'(
@ mags
     Thin and thick you are there buddy even though we quarrel manytimes
You are in my heart really :-*
@bob smith
Though i am not responding to you always, you are still there to support.
And i love you for that buddy. :)
Guess thats it?
Covid19 is getting nearer and nearer in my vicinity,
i'm an asthmatic, i don't know if i can survive if i got infected by this virus.
Hope we see in person each other someday.. :D
Finally the secret
None other than Tesla transformer!!! 8)
Do the avalantz its unlimitted controlled by your decision.
Back emf is the one that we can accumulate.
Bye now, hopefully please pray for me. :)
Just do the recursion infinite loop like in turbo c language. 8)
GOODBYE EVERYBODY
GOD BLESS ALL OF YOU
IN DANGER
TEETS ;D
Tito said it is a Tesla coil. Can we go there?
luc2010
HI,
@bistander,WhatIsItall my documentations is lost, i am so sorrywilliam barbat's self powered electrical generator patent, thats the only referrence i can remember for now.
