ENERGY AMPLIFICATION
EMJunkie
Kinetic Energy, where the very movement of a Charged Particle is defined as Energy!
Energy of Electrons in Atomic Orbitals
The central structure of an atom is the nucleus, which contains protons and neutrons. This nucleus is surrounded by electrons. Although these electrons all have the same charge and the same mass, each electron in an atom has a different amount of energy. Electrons with the lowest energy are found closest to the nucleus, where the attractive force of the positively charged nucleus is the greatest. Electrons that have higher energy are found further away.
Energy Quantization
When the energy of an atom is increased (for example, when a substance is heated), the energy of the electrons inside the atom is also increased—that is to say, the electrons get excited. For the excited electron to go back to its original energy, or ground state, it needs to release energy. One way an electron can release energy is by emitting light. Each element emits light at a specific frequency (or color) upon heating that corresponds to the energy of the electronic excitation.
It is helpful to think of this like going up a flight of steps. If you don't lift your foot enough, you will bump into the step and be stuck on the ground level. You need to lift your foot to the height of the step to move on. The same goes for electrons and the amount of energy they can have. This separating of electrons into energy units is called quantization of energy because there are only certain quantities of energy that an electron can have in an atom. The energy of the light released when an electron drops down from a higher energy level to a lower energy level is the same as the difference in energy between the two levels.
KEY TAKEAWAYS
Key Points
   If the energy of an atom is increased, an electron in the atom gets excited. To go back to its ground state, the electron releases energy. The energy of the light released when an electron drops in energy level is the same as the difference in energy between the two levels.
   Viewed simply, electrons are arranged in shells around an atom's nucleus. Electrons closest to the nucleus will have the lowest energy. Electrons further away from the nucleus will have higher energy. An atom's electron shell can accommodate 2n2 electrons (where n is the shell level).
   In a more realistic model, electrons move in atomic orbitals, or subshells. There are four different orbital shapes: s, p, d, and f. Within each shell, the s subshell is at a lower energy than the p. An orbital diagram is used to determine an atom's electron configuration.
   There are guidelines for determining the electron configuration of an atom. An electron will move to the orbital with lowest energy. Each orbital can hold only one electron pair. Electrons will separate as much as possible within a shell.
Key Terms
   frequency: The number of occurrences of a repeating event per unit of time.
   quantization: The process of approximating a continuous signal by a set of discrete symbols or integer values.
What are the fundamental processes in Freeing Electrons from Outer orbitals and allowing them to move?
This process is involved: https://www.youtube.com/watch?v=Vo2-Qb3fUYs
Smart people, will be able to see fundamental process here is exactly what occurs in an Electrical "Generator"!
ENERGY AMPLIFICATION, is achieved by Asymmetrical means, using this very same process! Tito L. Oracion, does this give you any more information on your threads query?
Best wishes, stay safe and well in these dire times,
   Chris Sykes
EMJunkie
Quote from: arhitrade on August 12, 2020, 12:49:25 AM
EMJunkie, here about it - with formulas: https://gorchilin.com/articles/free/magnetic_2?lang=en
Hey Arhitrade,
I believe Vyacheslav Gorchilin is correct and on the right track! I have not read all his work, but what I have read, it is almost exactly the same as mine!
If one of the Hertzian Wave forms costs you 0.9 of your Input and you get the second wave for free, then this is Energy, Asymmetrically birthed, that was not available to you before. Below, one of the Wave Forms, Magnetic B in Red and Electric, shown as Current I, is there simply because the other wave is there! Resonance is important in these systems, Magnetic Resonance, where each Current is 180 degrees out of phase to the other.
Study on this topic, you will see great progress! I have provided a great deal of information here: Partnered Output Coils - Builders Group - Moderated!
   Chris Sykes
elanimus
QuoteErgo, your supposed truth is not materialistic or based on facts but more so strange thoughts you believe are somehow not your own. What I find very interesting is how theists like to separate themselves from there beliefs or thoughts as you have. As you imply, "The truth lies one step beyond my thoughts", as a way to deny any responsibility for your actions. As if to say, I don't need to take responsibility for my beliefs or actions because something imaginary is controlling me. Classic psychosis whereby an individual has sensory experiences of things that do not exist and/or beliefs with no basis in reality.
It is not materialisit doesn't mean it cannot be fact. This is your material limit and bias on display. Actual reality lies beyond words and thoughts. For instance, the most important question which underlies everything is "who are you?", you can only answer this question with words and thoughts which are mere symbols but not the actual reality. This doesn't mean i am not responsible for my actions whatever that means. You are only in control of your mind to the extent that you know yourself. Religion and things of that nature are here to make this process less complex.
QuoteThe problem here is that once one becomes psychotic and detaches themselves from reality they are capable of almost anything. Not unlike the good christian man who went into the abortion clinic with a gun in one hand and a bible in the other blowing away doctors and nurses. He probably believed God wanted him to kill all those innocent people and that "the truth was greater than himself" thus he was not really responsible for his vile actions.
No, realizing the common sense that there's nuemnon underlying physical phenomena and also our consciousness doesn't mean disconnecting from reality LOl. The rest of your sentence is a fallacy, straw man? Again, i can flip it on you but the exceptions and exploitations do not represent the whole.
QuoteLook at donny trump and his almost exclusively elderly white christian supporters. Trump has been proven to be a narcissistic abusive compulsive liar who is consumed by greed and likes to grope young women. He represents everything theism tells us not to do and yet the christians champion him as there savior or chosen one. I suspect all those people also believe "the truth is beyond them" and they would probably vote for Adolf Hitler if they thought it would reinforce there beliefs.
I am not sure about the appropriateness of that statistics. But do you really really think trump represents a good Christian? Most Christians don't do these things and it's the atheists and nihilists in recent history who have been responsible for mass destruction.
QuoteSo we should understand the dangers involved with a mob or populist mentality whereby people seek to separate themselves and there beliefs from there actions in reality. So it was never a liberal/conservative problem, nor was it a social/economic issue in my opinion. What we have is large segments of society around the world who are no longer grounded in reality. They cannot accept the reality of there finite existence nor the changes occurring all around them so they have created an imaginary world to cope. This concept is proven in psychology and the trick here is critical thinking, to examine not only what we think but also how and why.
I agree, most people are idiots that's the source of all problem. You're just too obsessed with physical death that it has become the center of your emotions and thoughts. "People die, so life is meaningless and nothing matters." These are the sort of idiots who usually drown in escapism btw. Why are you so obsessed with death? I mean do you really think death is that frightening? Death is frightening only for people who are not living or are living in a limited egotistic universe. How can you not see the fact that you are connected to everything else? You can't exist without air, earth, light etc.. the same way a TV's signal stays after it's destroyed, the energies that moved you when were alive will live after you die. 99% of your physical body dies every year anyway, right? You are not just your body. https://en.wikipedia.org/wiki/Ship_of_Theseus
QuoteAnother interesting fact in psychology is that the criminal mind has similar thoughts. They lack empathy because in some sense they believe there thoughts and actions are not really there own. Not unlike a bipolar condition they have separated themselves and become a third person detached from there own thoughts and reality. Which is why they appear to lack empathy because in there strange twisted reality they are always innocent, a victim. We know this concept well don't we?... people always claiming to be the victim despite there actions?, a Red Flag in my opinion.
Religion is one awesome type of psychology. Btw are you using psychology as coping mechanism to escape reality bla bla bla? Exactly. No, that is a stretching of what i said, and you didn't really understand it. Knowing karma will only make you self aware and in control of yourself and understanding and emphatetic of others. Hahaha trust me knowing yourself is the opposite of having a victim mentality, i have argued with many people about this and ALWAYS the nihilists and atheists tend to see themselves as victims.
In any case, making up excuses for believing in imaginary things not justified in reality is not the way.
Religion is not about making up excuses. It's about understanding the nature of reality. Your understanding must at first be based on symbols which are not reality itself. This is true for the fake science of today, mythology and also our vision. It's like you're saying our eye vision is perfect and using reason(which is based on forms/ideas/angels) is believing in imaginary things
onepower
elanimus
QuoteI am not sure about the appropriateness of that statistics. But do you really really think trump represents a good Christian? Most Christians don't do these things and it's the atheists and nihilists in recent history who have been responsible for mass destruction.
I would agree most theists don't do bad things as individuals but they support people who do bad things. If atheist's are responsible for mass destruction then name one?. In fact almost every war and mass destruction was a religious war based on hate and contempt for the others beliefs not a lack of belief as Atheism.
QuoteI agree, most people are idiots that's the source of all problem. You're just too obsessed with physical death that it has become the center of your emotions and thoughts. "People die, so life is meaningless and nothing matters." These are the sort of idiots who usually drown in escapism btw.
I never said most people are idiots and disagree, most people are good in my opinion. As well your claim that "People die, so life is meaningless and nothing matters." is also false. Our life has meaning due to the fact we exist and our actions while we exist. It would seem to me the theists are the ones consumed by a fear of death hence the need for an imaginary after life and escapism from reality. You seem confused on this matter, Atheists do not believe in imaginary gods or an afterlife which in no way implies we fear death or need to escape reality, we think reality is pretty cool hence... Atheism.
QuoteHahaha trust me knowing yourself is the opposite of having a victim mentality, i have argued with many people about this and ALWAYS the nihilists and atheists tend to see themselves as victims.
My point was that donny trump is a psychopath and constantly whining how he is always a victim, how everything is a conspiracy against him and trumps supporters are almost exclusively elderly white christian's. Trumps supporters obviously bought into all the I'm the victim/conspiracy bs because they said so and continue to support trump. His supporters are so desperate they said they don't care how bad he is or what he does which sounds like a victim mentality to me. The only reason I care is because trump is a fascist who said he wants to be a dictator like Putin and Adolf. If trump becomes the next Adolf Hitler then obviously this effects everyone and it could start another world war. So I am no victim, simply the guy pointing out how false beliefs in imaginary things generally have disastrous results. You want to believe in imaginary things, elect psychopath dictators, destroy the planet and everyone on it, so be it but don't expect me to believe your bs while you do it.
QuoteReligion is not about making up excuses. It's about understanding the nature of reality. Your understanding must at first be based on symbols which are not reality itself. This is true for the fake science of today, mythology and also our vision. It's like you're saying our eye vision is perfect and using reason(which is based on forms/ideas/angels) is believing in imaginary things
So you think we should believe in imaginary things not reality and facts... Got it.
