ENERGY AMPLIFICATION
0 Members and 25 Guests are viewing this topic.
Quote from: Leely on June 01, 2021, 12:38:46 PM
LancaIV, this thing you posted about bar magnets on the sides of a metal bar, is there any other metal readily available other than metglass that shows any sign of amplification in that orientation? For me, I can't say if I know of any, yet.
This  sentences are from member Wesley/stivep his poste #8815 !
I will think about Your question and will then give answer !
Adeus
OCWL
stivep
You need to understand that there is no any real  amplification existing anywhere if energy  that is used  for "amplification" is not present.
-signal amplification  uses more energy that  summary energy of the signal and  its amplified level.
-horn is not amplifying the gramophone sound but is just sending  it in one direction and that what looks like amplification
is just the difference between coherent isotropic and directed anisotropic directional  effect.
the same is with  you  talking to the pipe  and listener listening from the other end of it.
However  resonance matters.
http://www.madsci.org/posts/archives/2001-07/996421645.Ph.r.html
https://www.quora.com/How-does-a-cone-amplify-sound
___________________________________________
For  unconvinced  there is set of questions:
how does sound get amplified when passed through a cone?
where does the extra energy come from?
What about hollow objects like a box guitar?
how do they amplify sound?
http://www.madsci.org/posts/archives/2001-07/996421645.Ph.q.html
________________________________________________________________
So in any possible classical mechanic or quantum mechanic phenomena the effect is always
smaller than summary amount of energy used  to achieve it.
Directional antenna Yagi having in dB gain of 15 dB  is not gaining anything at all.
It is just taking the same energy from Tx  that could be connected to  e.g omnidirectional  antenna.
The difference  between the two is that:
-YAGI SENDS THIS ENERGY in one direction only.
- omnidirectional antenna  sends 1/360ties of Tx energy in the same  direction.
Yes you gain in dollars walking home  instead of  taking taxi,
but you losing on energy of your body.
So why we are talking about Free Energy?
Because we don't care who pays for that energy  as long as we get  some of it for free.
So any device  and every device must  use  its energy to couple  to someone-else energy.
example is a pipe with water.
if that pipe is connected to the river and your energy is just used to open the valve  than you have Kapanadze device.
In energy extraction from Schumann waveguide nature pays for energy and its delivery  and you are only  the "valve opener"
So looking for  energy amplification  you need to know that none  of it  exist in net value.
it is not important if you use metaglass or anything else.
Wesley
Excuse-moi, "energy livre ":      free Voltage/tension
                                              free Voltage-h + free Amperage-h = VAh
                                              syntax !
                                              like the often power instead energy or vice-versa termination use error !
Salute
OCWL
Leely
Quote from: stivep on June 01, 2021, 01:26:44 PM
-signal amplification  uses more energy that  summary energy of the signal and  its amplified level....
Wesley
Yeah, I still see it this way. There are stored energies which we may term as artificial, and there are natural energies which we see as abundant. The artificial or stored energies has lifetime, it has expiring date. I still believe that metglas, when used in an amplification mode has expiring date, it only depends how long.
I always have this weird feeling when I'm trying to build an earth based free energy machine, as if the oil companies will come after me. Was my mind playing games with me. When I try to build the ones that don't use the ground for amplification, I feel better.
Leely,this all makes part from appropriate R&D about periodic/permanent moving devices and their maintenance :
coils are given 80 000 hours work life( 1 year = 8766 hours !)
permanent magnets (without extrem demagnitization cases like abnormal heat/Barkhausen et cet.):
by Arpad Boday to read up to "1000 years" RE-magnets
bears : 10v6 revolutions,SKF reference  ( seems much but by 3000/6000 RPM and 1 year = 8766x60 RM if permanent "relativ" )
Transformer core : rust risc
free energy is never technical meaned as " eternal converting/generating device/machine " !
As decay sources these devices exist ! Thermoelectric battery/generator
And we have to plan with inexhaustable materials and production capacity and the people their average skills to construct,to montage together or to repair and changing friction parts without commercial on-profit service !
For many actually it is in rural zones a day-by-day problem to get for conventional machines spare parts,when the next greater city with electric devices repair shop is 50/100 and more Kms away and no/bad traffic routes !
And does new production from older models exist ? 3D reprint ?
How work the old car owner in Kuba to organize spare parts for 30' 40' 50' models  !?
For the Upper 10 000 to build the OU-machine is not a need,for the nether billions an simple OU-machine the solution for water getting ( pump),light,fridge/freezer as most important application !
But they can also live with non-em-OU technologie ! Pure mechanical thermo-cryo-dynamic cycle !
Solar freezer( zeolith or active carbon),light pipe( bottle),hydro-ram-pump, ......
Sincere
OCWL
