ENERGY AMPLIFICATION
0 Members and 50 Guests are viewing this topic.
(Chill)
I heared from somewhere about a behaviour named ' gentleman's agreement ' !I do not really know from where !?  ::)
But let us go ,virtually,entering :britannica and read about 'matter' !
matter ,materia(l) and ,together with energy,....
anti-matter
anti-energy
Quark
Anti-Quark
Now silently departing
OCWL
p.s.:        - or   + ,ccw or cw,(pro-) or anti -  left or right,above or below,super or sub
               attraction is stronger in force than repulsion ( JLNLabs experiments) or vice- versa ?
               ccw energie as same in force units as cw energy ?
               on Earth    super-aequatorial/sub-aequatorial line dependent ?
               North-/South-hemisphere and Coriolisforce-and direction as comparison-' object' ?
              Coanda,Flettner,Meissner(-Ochsenfeld Effect,also in supra-conduction to see )
nix85
There are streams of subtle matter swirling around earth, these are the source OU devices tap into.
"The main etheric flows in the temperate zones run from west to east, and in the equator, the main flow is from east to west. There are large differences in temperate zone etheric densities and response times compared to (faster) equator. The west to east flow of ether in the northern hemisphere is strongest at full moon, and weakest at new moon. There is also south to north terrestrial flow of ether in the northern hemisphere spring and summer, and in the winter this flow reverses. The west to east flow and the south to north flow are separate functions of the ether, but to some degree they mutually influence each other."
Constable, Trevor J. 1990. Etheric Rain Engineering
Floor
nix85 quote
"2kg x 4m/s = 8kJ all is perfectly clear and assumed. Units don't even matter as long as they are on same scale (kg vs m/s etc) nor does 1/2, proportionality does. Since you grab onto irrelevant, i'll state the obvious that using the 1/2 OBVIOUSLY the result is 4kJ (not J as you wrote)."
end of nix85 quote
         Wikipedia quote
"For example, one would calculate the kinetic energy of an 80 kg mass (about 180 lbs)
traveling at 18 meters per second (about 40 mph, or 65 km/h) as Ek = 1/2 • 80 • (18m/s)^2
= 12960 J = 12.96 kJ "
   end of wikipedia quote
1/2 x 80 = 40
18^2  = 324
40 x 324 = 12960 joules...  and not kilojoules
nix85 quote
"2kg x 4m/s = 8kJ all is perfectly clear and assumed."
end of nix85 quote
                      wrong
a 2kg mass moving at 4m/s velocity has
              16 j of kinetic energy and    NO not 8kj
1/2 x 2kg x 4m/s^2
1/2 x 2 kg = 1
4m/s2 = 16
1 x 16 = 16 j
nix85 quote
"Units don't even matter as long as they are on same scale (kg vs m/s etc) nor
does 1/2, proportionality does."
Your statement doesn't even make sense.
Some times posts from a word processor don't transcribe correctly to an O.U post.
Example: exponets may be missing or show up on the posts in a normal font position
insted of as a superscript.
Get some sleep.
I'm out of here
    peace out
      floor
     PS
   thank you
        LankIV
nix85
HA! I wrote that in a rush and corrected it immediately, I KNEW you're gonna grab onto that like a desperate dog. Especially considering you replied 1 hour and a half after the correction has been made. :) Pathetic.
"Your statement doesn't even make sense."
It would make sense to you if you had brains. We are talking energy gain in superposition of waves. You brought up the kinetic energy comparison where no such gain even theoretically occurs. Units and the 1/2 factor do not matter in this context. What matters is that kinetic energy of two masses before and after they are added together is exactly the same. Thus parallel is nonsensical.
Yet based on it you conclude "This is not free energy" :) Genius
"Get some sleep"
HA! You get some sleep and some new brains.
nix85
Here is a quote from George Van Tassel's book When stars look down about German study which apparently verified the Earth grid. Grid is mentioned in many alternative sources, occult, contactee, NDE cases etc. Also reminds me Ed Leedskalnin moved his whole Coral Castle, i can't remember the exact quote but it had something to do with the grid, new location was apparently more susceptible to degravitation.
"Rock Gate Park, as Edward Leedskalnin called the place, began construction originally in Florida City around 1923. In 1936, Edward began a three year move of his structure about 10 miles (16 km) north to its current location in Homestead, Florida, at the intersection of U.S. 1 (South Dixie Highway) and Southwest 157th Ave. He continued its construction in the new location until his death in 1951."
From When stars look down:
A book, published in the German language, in Innsbruck, Austria in
1952, explains the findings of outstanding researchers into the earths
power grid system. The title of this book is "The World of the Secret
Forces." In German, "Die Welt Der Geheimen Machte."
The men involved are Dr. Willi Schlosser, Prof. Hellmut Wolff,
Hans-Wilhelm Smolik, Heinrich Reblitz, Theodor Weimann, Herbert
A. Lohlein, Ferdinand Reich, Univ. Prof. Dr. Hubert J. Urban, Dir.
Prof. Dr. K. Saller, Prof. Dr. Georg Anschutz, Prof. Dr. Theol and
Adolf Koberle. Quite an impressive group of qualified professional
people, to agree, and be involved in one book. They established that
the earth is covered on the surface by a grid system of positive and
negative poles in a checkerboard pattern.
Excerpts from the book are as follows:
"Each of the squares has a center pole surrounded by 8 smaller poles.
(Here again is the Chinese Cosmic Flower, the Hubbard Coils, the
Tesla System of extracting energy from the earth. Ed.)
These squares vary in size from the equator, getting smaller in the
direction of the earths poles. The main pole concentrates energy. At
North Latitude 48° (The latitude where these men conducted their
research. Ed.) the center pole has a diameter of 2.45 meters. The 8
smaller poles have a diameter of 60 c.m. Four of the 8 outer poles
(alternately) send energy up toward the sky. The other four send
energy outward horizontally to North, South, East and West.
The squares (48° N. Latitude) are 15.90 meters diagonally from
center to center poles.
N/sinus 45° = 15.9/0.707 = 22.5 meters
A border field is mingled together in the Northwest and Southeast
directions and in the Southwest and Northeast directions, These 4 cor-
ners of the squares seem to connect the fields of 2 of the negative
smaller poles and two of the positive smaller poles.
At these points any person (or body) will receive a mixture of nega-
tive and positive energies.
The side length measurements at the equator are 32 meters long. It
was found out that the earth between its North and South Poles was a
"stick" magnet. On this magnetic field there are electric currents per-
pendicular to the "stick" magnet.
Strange to say that the Cheops pyramid on the 30° North latitude,
stands on a diagonal measurement of the pole field of 30 meters on
each side of the squares.
The main center poles of each positive square shows a direction of
energy from above to below the earths surface. There a vortex is cre-
ated with a pulse like the hand of a clock. The negative poles are vice
versa.
Dr. Rohracher, of the University of Vienna made a very sensitive
electro-magnetic tuning fork (The Hendershot device also has a mag-
netic tuning fork. Ed.) that showed from 7 to 18 movements per sec-
ond. Prof. Dr. Regelsberger made an electrometer which showed
electric impulses of 10 millionth of an amp.
Dr. Muller, from Zurich, Switzerland, measured the electric field on
the human body. The body "aura" will change if you move into a dif-
ferent location.
This means the magnetic or electric field of the earth is different.
The 'dowsing rod' can locate the center of these positive and nega-
tive poles. These measurements should be made with different lengths
of 'dowsing rods. The length gives different wave length readings.
The point you find with the rod is a knot of a free standing wave.
- (We call this energy point a 'time zone' or 'this other energy.' It is not
magnetic, or electric. Hieronymous calls it 'Eloptic Energy.' Ed.)
The 'aura' of the human body will be charged on all positive polarity
pole centers and it will discharge the human 'aura' on all negative
poles until no aura is registered. This is how one can register whether
the poles are positive, or negative.
These experiments are physiologically and psychologically of the
greatest importance to health. Whoever goes into the secret of the
earths ray powers will know the wheel of destiny.
These powers are free, not the power from our power plants. These
in and out powers have to do with the human organism. The trouble
zones and health zones have to do with the movement of the planets
and stars. In the micro-cosmos it (the earth) is the electron that is in `
the command of our creator. (What a statement to come from these
distinguished men. Ed.)
This is the pattern of the secret of creation and this is why the
Chinese speak of the secret of the golden blossom.
It is well known that there are rows of cancer houses in certain
towns and most of these inhabitants are dying of this terrible sickness.
The dowsers have proven that the bedrooms of cancer patients are on
the grid crossings of the trouble zones.
Waldemar V. Jankowsky wrote about the cancer problem and said
the light quantum and the Pi-electron are the cause. The dowsers
proved these trouble zones are in the positive fields. Frh. V. Pohl wrote;
'earth beams are sickness exciters. We could find the positive fields by
experiments? `
The places of the negative polar fields shows entirely different effects
on the human organism. Now here is an entirely new field for search-
ing doctors who are interested in the world of fine beams. Through
this effect the life span of the human can be changed." (This verifies
what we are trying to do with the "Integratron" machine. Ed.)
Captain Bruce Cathie's two books "Harmonic 33" and "Harmonic
695" seem to follow a pattern "township" grid composed of many of
the smaller grids like "sections."
It is strange that the German material and Cathies grids coincide on
the great pyramid, and other points on the earths surface. These re-
searches conducted years apart and on opposite sides of the globe tend
to verify each other.
The fact that microwave transmissions, and receptions, are being
carried on through the earths surface by coordinating resonance at
different points, is proof that secret scientific people are already aware
of the great potentials of the grid system for power, navigation, and
antigravity directional control.
Baxter's research with plants; the Hieronymous research with insects;
research into bio-transducers by L. George Laurence; Kirlian photo-
graphy; acupuncture, and numerous other aspects are verifying each
other.
In the "Proceedings" of November 1953, on page five we explained
the "earths force field." Four years later science verified this and called
it the "Van Allen Radiation Belt." In the 1953 article we printed: "this
ring maintains balanced interchange of power through the crust and
atmosphere of this planet."
In the Septémber-October 1965 issue of the "Proceedings," on page
4, we wrote up the earth forces in an article titled, "This Amazing
Armature." In the 1965 article we said, ^There are other fields in the
earths bulk that are not measurable with a magnetic instrument such
as a compass. These fields, and currents are the carriers and distributors
of what we call 'life force.' This 'life force' is only measurable and de-
tectable through 'living' instruments and it is also subject to thought."
If people knew they were living in a positive square on the earth they
would move, or be subject to the physical ailments caused by it.
This article could go on indefinitely, because there is not enough re-
search going on for the benefit of people, and too much going on for
their detriment.
Mrs. Ford, the Presidents wife, and Mrs. Rockefeller, having to suffer
the conditions of breast cancer surgery, is proof that the detrimental
forces can affect people in the highest positions in life.
It looks like the government would appropriate more money to study
these forces and subsidize those people who are already involved in the
research into this "life force."
