ENERGY AMPLIFICATION
0 Members and 56 Guests are viewing this topic.
AlienGrey
Quote from: Bob Smith on June 07, 2022, 10:03:12 PM
Thanks for the reply, Forest
I guess it would take a while to get the capacitor up to full charge with the JT. But once you're there, I can see there would be quite a momentum leaving it.  Kind of reminds me of Don Smith's work with the HV cap to coil(s) and ground.
Regards,
Bob
Bob
Look Bob some guy who use to frequent these pages named Nelson showed on his youtube pages
how to do what your asking about amplification, just generating high voltage at high current isn't it!
all he did was to generate high voltage at low current and then add a low voltage high current to it.
So as both wave forms coincide.
Can i suggest you look into that trick to exploit.
Sil
NickZ
   AG:   Get it through your head that Nelson does not have FE on any of his devices. No self running, just efficient use of the energy from the battery. That's all.  Waste all the time you need...that is all we've ever had. Wasted time, and not a single FE device.
So why do you want to continue with this run around, if you really want to get somewhere? You won't find it here, nor will any one else. This thread is as useless as all the rest.
   NickZ
AlienGrey
Ha, ha, carfuly chosen words by Nelson, if you excelerate electrons use a tesla coil.
Unless you play the game you will never get your device to work
Have you tride removing that iron from inside your grenade and putting
baking foil up its bum the full length but not a shorted turn and tuning it correctly ?
if you dont want to bother your on your own.
Bob Smith
Quote from: AlienGrey on June 11, 2022, 08:32:42 AM
Bob
Sil
Thanks Sil!
Bob Smith
Quote from: Tito L. Oracion on September 22, 2013, 03:37:01 AM
The automatic successive kick started from the small kick is the way to be. ;)
JUST DO IT!!!  :)
IT SHOULD BE SMALL kick then it kick->KICK
                                                            KICK.  8)
OTITS  ;D
It just struck me, BEMF, not just ringing down.
Hope you're well, Teets.
Bob
