ENERGY AMPLIFICATION
0 Members and 56 Guests are viewing this topic.
e2matrix
Information relevant to the above 2 pics:  "Figures 3-36 and 3-37 both represent practical, workable saturable-core reactors. Circuits similar to
these are actually used to control lighting in auditoriums or electric industrial furnaces. These circuits are
sometimes referred to as magnetic amplifiers, but that is NOT technically correct. A magnetic amplifier
differs from a saturable-core reactor in one important aspect: A magnetic amplifier has a rectifier in
addition to a saturable-core reactor.
Q-42.
If the permeability of the core of a coil increases, what happens to (a) inductance and (b) true
power in the circuit?
Q-43.
What happens to the permeability of an iron core as the current increases from the operating
point to a large value?
Q-44.
If two coils are wound on a single iron core, what will a change in current in one coil cause in
the other coil?
Q-45.
What symbol in figure 3-33 indicates a saturable core connecting two windings?
SIMPLIFIED MAGNETIC AMPLIFIER CIRCUITRY
If the saturable-core reactor works, why do we need to add a rectifier to produce a magnetic
amplifier? To answer this question, recall that in NEETS, Module 2â€"Introduction to Alternating Current
and Transformers, you were told about hysteresis loss. Hysteresis loss occurs because the a.c. applied to a
coil causes the tiny molecular magnets (or electron-spin directions) to realign as the polarity of the a.c.
changes. This realignment uses up power. The power that is used for realignment is a loss as far as the
rest of the circuit is concerned. Because of this hysteresis loss in the saturable-core reactor, the power
gain is relatively low. A rectifier added to the load circuit will eliminate the hysteresis loss and increase
the gain. This is because the rectifier allows current to flow in only one direction through the load coils."
forest
Is magnetic amplifier possible using on core ?
I don't understand how it magnify power. By breaking wave at the peak ? No lenz law ?
Doug1
Here forest
http://www.themeasuringsystemofthegods.com/magnetic%20amplifiers.pdf
Not sure where they got the copy from I even cosidered not mentioning it due to the website name.
Qwert
Tito L. Oracion
Quote from: e2matrix on March 01, 2011, 10:19:20 PM
So if I reveal the secret will you reveal everything ?
First I'll admit I have not read this entire thread but only the first couple and last couple pages.  But a lot of things seem to point to this concept.  The magnetic amplifier circuit which is simple but fell out of use when solid state components became popular.
Oh well. this scheme is other way but this is different than mine and you just added some juice in my brain. hmmmm i think its time to scrutinize this one. thanks bro.  ;)
I admit, i'm learning more  ;D
Well ok, here is what i'm doing currently.
I am redirecting the input and the effect of that input into the source, and so the effect is self recharging. take note this is just one of my latest scruitinizing.  ;D
and i think i can add up what you taught above thanks  ;)
