ENERGY AMPLIFICATION
0 Members and 663 Guests are viewing this topic.
ramset
OK, Teestla said a cap charging senario!
These fellows at OUR ,seem to be discussing this
A snipet bellow
Core
Quote:
In the book 'Tesla on his work with Alternating Currents' by Leland Anderson does anybody know what device the cover diagram is for. It is pictured next to the Magnifying transmitter but I do not think that is it. The diagram shows capacitors charged in parallel and discharged in series. I might be missing the patent that this one is for. Any help would be great.
Respectfully,
Core
Cover diagram.
""""Image posted below"""""
darkspeed
Group: Darkspeed
Core,
That was the driver for the single wire primary that went around the perimeter of teslas lab. It allowed him to walk around the lab with tuned devices that would run off the primary discharge.
Core
Darkspeed,
  As far as you know is there any additional data on this? This is one of the very few diagrams that show a core material. Also to power a tuned device would one end need to be grounded?
Respectfully,
Core
darkspeed
Group: Darkspeed
The first transformer with core is a low frequency step up transformer like a neon sign transformer.
It feeds resonant charging inductors, then capacitors.
When the rotary gap fires the long single wire is in LC with the capacitors and a high frequency is established.
No ground is needed, however a ground will increase the output of the tuned receiver.
Adding a ground allows you to use the electrostatic component between the top of the receiver and ground
allcanadian
@Core
This is Tesla's hairpin circuit with a mechanical break or a better term would be rotary spark gap which disrupts the circuit. The capacitors are charged in series through chokes to limit current from the secondary and when the break fires the capacitors are discharged through this same path. The changing potential on the capacitors produces a sharp impulse in the loop (a single turn coil) which induces the device(the receiver) in the center of the loop which has a break as well fired at a rate in proportional to the primary break. A variable inductance can also be seen in the loop for tuning the device to resonance.
AC
Thanks Grandma
ramset
More Comments from the boys at OUR
Reguarding Parallel to series cap stuff!
dllabare
Quote:
Core
I found this little write up regarding the picture you posted:
"Figure 35.
Apparatus with mechanical break as installed on a large scale in the laboratory at South Fifth Avenue and subsequently at 46 East Houston Street.  Described in U.S. Patent No. 645,576 of March 20, 1900.  Application filed September 2, 1897.
This [Fig. 35] is the apparatus I had at 35 South Fifth Avenue and also Houston Street.  It shows the whole arrangement as I had it for the demonstration of effects which I investigated.
•This cable you see [square loop in top half of Fig. 35] is stretched around the hall.  These are my condensers.  There is the mechanically operated break, and that is a transformer charged from the generator.  That is the way I had it for the production of current effects which were rather of damped character because, at that period, I used circuits of great activity which radiated rapidly.  In the Houston Street laboratory, I could take in my hands a coil tuned to my body and collect 3/4 horsepower anywhere in the room without tangible connection, and I have often disillusioned my visitors in regard to such wonderful effects.  Sometimes, I would produce flames shooting out from my head and run a motor in my hands, or light six or eight lamps.  They could not understand these manifestations of energy and thought that it was a genuine transmission of power.  I told them that these phenomena were wonderful, but that a system of transmission, based on the same principle, was absolutely worthless.  It was a transmission by electromagnetic waves.  The solution lay in a different direction.  I am showing you this [diagram] simply as a typical form of apparatus of that period, and if you go over the literature of the present day you will find that the newest arrangements have nothing better to show.
Counsel
What was the make and break frequency that you got from that apparatus?
Tesla
It was 5,000, 6,000â€"sometimes higher still.  I had two oppositely rotating discs which I will show you and with which I could have reached, probably, 15,000 or 18,000.
Counsel
What wave frequencies did you develop?
Tesla
I could operate from a few thousand up to a million per second, if I wanted.
Counsel
What did you actually use?
Tesla
In these demonstrations, which I showed these effects, these most powerful effects that were the sight of New York at that time, I operated with frequencies from 30,000 to 80,000.  At that time I could pick up a wire, coil it up, and tell what the vibration would be, without any test, because I was experimenting day and night."
Thanks Grandma
slapper
adding my 1.5 cents :)
take care.
nap
we are not alone :)
kooler
what is this ..
it looks like a highly adjustable tesla hair pin..
but has two air coils coming off the high tension side of the input transformer..
what are those for.. ?? would they mate together.. to help feed the caps with b.e.m.f.  ??
robbie
Tito L. Oracion
That is were energy is being suck.
An open door to get energy in the environment
A vacuum effect for energy outside.
That is how i see it  ;D
;D
