Thanks to ALL for your help!!
Increasing magnetic fields for magnet motor
Started by gravityblock, February 14, 2009, 08:40:28 PM
gravityblock
Here is some sketches to spur some thought around the Magnetic Motor Theory.
Again most people will say it is impossible and whomever thinks it is possible is a Crack Pot - But I can show you the raw prototype that makes you think twice.
How do we get the wheel running from the North Pole to the South Pole on increasing magnetic fields to reverse itself at the bottom and allow it to continue without any assistance or breaking point.
Below is the link to download the sketches. There are 4 .png files inside the zip file. They are high resolution sketches and you will need to zoom into specific areas on the drawings to see the writing. The zip file is 5.2MB in size. I will show 4 small thumbnail pics below also.
Download Link - magnetMotor.ziphttp://tinyurl.com/bg9ece
Thumbnails:
gravityblock
I made the thumbnails larger for those who don't want to download the higher resolution pics in the zip file.
Larger Thumbnails:
mike444
Nobody responded to this?  ???
Were you able to ever test this? This seems like a very important question: Will this work?
I would probably suggest making the ascending magnets static and the middle armature movable instead simply because it would take more force to move the whole magnet configuration than it would a lightweight revolving middle armature.
Oh wait, I see you got that in thumb3.
mr_bojangles
it seems similar to using uniform strength magnets at increasing distances, but that might be the key to it
the only thing i can think of, you have two transitions from big to small, would that make 2 "sticky" spots?
i wonder if it might have less friction with only one transition, or possibly stagger them so while one is going through, the other is on track and vice versa for the latter
i like how the magnets create a unified distance from the runner, hopefully the larger magnet will kick it through it
"If at first you don't succeed, try, try again. Then quit. There's no point in being a damn fool about it."
-WC Fields
Judges
HELP,,,,this,,,,http://tinyurl.com/bg9ece,,,,keeps sending me to a coin buying site.
Really would like to see details.
Looking for a new project to start on,,,this MIGHT be it.
Joe in Texas
GB,,can you send the zip file to my email,,,joesmith@cvctx.com? or some other way????????
also,I will not miss-lead you.IF
I do not want to try building it,,Then I will state this.
