Four things required for any gravity power device to work
Started by brian334, February 19, 2009, 05:43:22 PM
myrmex
anyone has tried to use the eddie current law that makes a magnet fall slowly in a tube of aluminium or copper to reduce the weight( creates drag) on the downside or the upside ?
http://www.youtube.com/watch?v=pcVG6c_OvYU&feature=related
im sure it would be worth a shot to try if you use magnet as your weigth in a wheel.
brian334
1. On the down side the object must be heavier than the same object on the up side.
2. At the bottom the object must change from being heavier on the down side to being lighter on the up side.
3. On the up side the object must be lighter than the same object was the down side.
4. At the top the object must change back from being lighter on the up side to heavier on the down side.
The important question is how can this happen?
AB Hammer
Quote from: brian334 on April 16, 2009, 06:16:45 PM
Greetings Brian334
I would say descending and ascending sides. But you are correct for standard approaches. Bessler made the statement that to keep the weight on one side and not the other as well.
Alan
Yortuk Festrunk
The answer is to RELAY a weight from six o'clock STRAIGHT UP THE MIDDLE to twelve o'clock!
This type of wheel will not turn continuously, rather, it would turn 180°, stop, pass the weight back to the top, then turn 180° again, stop, and so on.
The question is: Would this stop and go action be a detriment to trying to get useful work from this device?
3decimal14
By making object spin!
According to "Bruce DePalma - Spinning Ball Experiments" a spinning object falls faster and ALSO going up faster compared to non spinning object. Se this page:
http://www.evert.de/eft907e.htm
/Thanks
