Acoustomagnetic TPU / SEG calculation model
Started by Magnon, February 21, 2009, 10:16:08 AM
otto
Hello all,
Im the next 15 or so days on vacation. No internet at home so I will be quiet for a time.
ITS TPU TIME for me.
@Tito....
its good to try the copper but ......just use a lamp wire, place it along the copper core as a collector and pulse this collector with 3 frequencies. Of course in paralel with the pulses on 1 side and the + 24V on the other side, connect a 100W bulb.
Then, another collector......then maybe a 3. collector.......enjoy in the light.
Otto
otto
Hello all,
sorry guys I forgot:
Im talking about a 15" TPU!!!
Otto
giantkiller
Quote from: otto on April 21, 2009, 04:25:46 AM
Hello all,
@Phantasm
I tried to use iron powder cores taken from TV deflection systems. I pulsed them and with 24V/5A I managed to light a 100W bulb with full light. The cores, hot, the MOSFETs very hot.
Then I got a lot of best quality Metglas and used this as a core. No reaction, to say so. The Metglas core didnt work.
Now Im using a copper pipe as a core. Its the best!!
SM told us in his way to use Copper and Alumimium in our TPUs but nobody is listening.
Its clear ( at least for me) that various plastics also can work in a TPU but I dont want to work with plastics because my copper core is a real beauty.
I think that iron resists to much to the flow of the particles. They are somehow penetrating the iron powder core.
Totally different is it when you use Metglas as a core. The particles are only striving over this metal and nothing happens.
Copper is between the mentioned 2 metals. When I short the core I see nice sparcs. This doesnt happen with iron powder but happens with Metglas. Not sooo strong as with copper but still to see.
Otto
PS: is here a TPU builder that listens or Im wrighting for nothing???  Heeeeeyyyyy, GK, Roberto....
@Otto,
I follow closely, very closely!
I too suggested copper pipe. The spool of bendable copper used for ice makers in refrigerators. This is the highest quantity of lowest price ratio you can get. Why? because you can easily form it to your needs. I was even going to pour aluminum shavings down the middle to cause the copper magnetic field to stay outside! Check that out! I had more up my sleeve than I let out. That is why the rail gun docos appeared. Instead of using a magnetic field to propel a aluminum projectile I was aiming to push the magnetic field with an aluminum shield.  ;) One could also push a piece of insulated or non-ins aluminum 12awg house wire down the middle.
I was going to reproduce the GK4 with these cores. It was suggested I hold off because of my proximity to a radar base and percocious exurberance. The copper does not hold on to the current, nothing gets trapped inside like with iron. In copper, the magnetic field compresses in the center. That is why the Leedskalnin docos appeared. The iron, for my design, slowed down the catalyst. Lucky me.
@ All,
Otto, I, and a few others have gotten hurt. It don't feel good and there is nothing the medical community can do for you.
--giantkiller.
Magnon
Like i told before, the spin wave from acoustomagnetic resonance effect is a helical type wave and therefore has a rotating polarization.
The direction of spin wave rotation depends on direction of applied magnetic field and radiation direction follows the direction of the applied field.
It is important to have both N and S applied magnetic fields in a device, to have both right hand spin wave rotation and left hand spin wave rotation, like it is with a SEG, that is magnetized in a direction h. This kind of system is needed to compress the spacetime. This same kind of applied magnetic field we must build in a TPU core.
--Magnon
Phantasm
Quote from: giantkiller on April 21, 2009, 11:00:28 AM
@Otto,
@ All,
--giantkiller.
Interesting
I was just going to get some solid copper rods and bend them in to rings and use those as cores...Do you think it would be better to fill copper tubes with fine grain aluminum shavings?
