Mt 24 reviewed
Started by BAHammer, February 25, 2009, 11:08:22 AM
erickdt
Gearing mechanisms and scizzor jacks will not work in such arrangements because it will always take the same ammount of input + more input to account for mechanical losses to make them work in which case you would have been better off not having those devices to begin with (because you've un-necessarily complicated the system causing more losses and a net reduction in output).
BAHammer
Quote from: erickdt on March 03, 2009, 11:00:51 AM
  erickdt,
Check the drawing, the math in the My Current Build thread.
It will explain what in math allows it to work. The trick is that a 2.5 lb.
weight can lift a 5 lb. weight. The weight hanging down from the fixed arm only assists
in the lifting. It might help to time when the weights shift positions. But if the elver does most of the work, then it would depend on the rotation of the wheel.
The weight being lifted would only be lifted 1/2 the drop of the lever. It can work  :)
erickdt
Quote from: BAHammer on March 03, 2009, 03:22:21 PM
  erickdt,
The fact that the lever needs to be twice as long on one side of the pivot as the other (in order to lift the 5 lb weight) will result in the 2.5 lb weight canceling out any net torque you might have gained...
grayone
Sorry :'( I was hoping for something better due to the first drawing.
FreeEnergy
just build the damn thing already and lets see if it works.
