New inventor of a Watercar (Bike)
Started by rensseak, January 17, 2006, 02:19:10 AM
buzneg
Where can I buy these metals that disolve in water to produce H? Magnesium makes H would it be the best bet? Wouldn't want anyother gases to be produced as they might take up space in the water.
Bruce_TPU
I believe that Ryan used a Chemical, probably HCL (muriatic acid).  When Nickel is placed in HCL there is no reation.  But if you leave the Nickel in the HCL and run a wire attached to the Nickel and attach it to a piece of Zinc it will bubble up hydrogen gas.
I have included a link for you to see these experiments I ran across.
http://jchemed.chem.wisc.edu/JCESoft/CCA/CCA3/MAIN/VOLTAGE/PAGE1.HTM
I think when Ryan connected the wires, he started this hydrogen reaction, under pressure in the sealed box and supersaturated the water with pure hydrogen.
I typo'd in my last post.  I believe the other resoivar in the box was HCL (muriatic acid) as I posted at an earlier date. Click the link above to see how I believe it was done.
pg46
Hi buzneg-
One of the easiest methods to produce hydrogen gas is to place some scrap aluminum into water that has some potassium hydroxide(KOH) or some sodium hydroxide(called NaOH, caustic soda or lye). Careful though as the reaction can get very violent and very hot. The hotter it gets the faster the reaction.
I forget just now but I think that zinc in sulphuric acid will produce some hydrogen gas as well.
Protect your eyes and skin when fooling around with these chemicals because they are very dangerous if not handled properly!
btentzer is talking about different methods where two different metals placed in certain solutions and then connected will produce hydrogen. I too believe this is what Ryan has done. Not sure what the solution and metals he uses as there are several variations available I think to produce similar results. I wonder if he is producing just hydrogen gas or both hydrogen and oxygen(hydroxy)? If he is just making hydrogen then I wonder what the oxygen molecule attaches itself to and if that won't gunk up your container after a while requiring some periodic cleaning out?
Well, what is most important is not how Ryan makes the hydrogen but whether if when water is super saturated with hydrogen, will that water explode when put into the cylinder of an IC engine and fired? That's the main question that needs to be answered.
Bruce_TPU
Quote from: pg46 on May 06, 2007, 01:20:31 AM
Well spoken!  This is the question that needs to be answered.  Who has a small IC motor they can experiment with?
MarkEngr
Would you need to change the timing in the motor or could you simply charge the water and pour it in? I cant remember if they said anything about the mechanics of the bike in the video. I am going to watch it again.
