PLEASE PUT WORKING CIRCUITS only HERE (for everybody please give a share)
Started by Tito L. Oracion, March 03, 2009, 08:19:49 AM
MrMag
Quote from: Tito L. Oracion on June 24, 2011, 04:27:43 AM
To everyone
A real working circuit is just a matter of efficiency.
making a ringing effect inside the two caps prohibiting a discharging action from the source, and as it is ringing then a magnification is being done at the other coil.  ;)
Yeah right. ::)
forest
Quote from: MrMag on June 25, 2011, 05:24:59 AM
Yeah right. ::)
C'mon. Tito cannot be more clear ! He is really trying to tell us, please be open minded.This is capacitive method of eliminating Lenz rule.
Tito, can you explain what is that BEMF, how is related to Lenz rule ? I know about Newton third law but still my mind is not working clearly enough to understand what is the nature of this effect.
I will explain what I know because time is short : when we have capacitor and coil in resonant circut there is one resonant frequency and many harmonics. If we put a bit energy inside it will vibrate while converting between magnetic and electric side : when it is charging capacitor it always flip-flop electric dipole in capacitor. You see now where is the problem ... capacitor is connected to the power source and working against it (sometimes). Clever man would try powering it from magnetic field but again there is a change ( I think) in magnetic dipole which acts against the initial magnetic power source.
Now look what Tesla done and think...efficient use of power source by capacitive method of eliminating lenz rule. Tesla named it "charges funnel"
You really don't know how hard is to feel that but have no ability to construct a working device  :'( I'm trying and trying and trying and what can ordinary poor man do from a piece of wood and a bunch of wires ? Everything ... if he has a plan of already working simple device..and nothing - if he is trying to build one in experimental stage  >:( where everything should be precisely measured and constructed for resonance, for example switching device.
MrMag
Forest,
Like this?   http://www.walter-fendt.de/ph14e/osccirc.htm
And Tito, don't try to put it on me. YOU are the one who said he was going to share his discovery and then it was YOU who decided not to share it. That was BEFORE anyone started to make you sad.
forest
SchubertReijiMaigo
Forest
QuoteThe secret is one : why it is so hard to build a working device when I have plenty of ideas ?  ;D
See... - I can see it working in my mind but cannot make one...  how to break that barrier ?
In my case this more a lack of money than a lack of idea or experiment, for example The Tesla/Gabriel device have a nanoperm toroid (I wonder if this necessary for operating since this is more like a magnetic diode than the Heins effect permeability gradient...) This nanoperm cost me over 100 Euros, and I have the odered on Ebay the shield about 39 Dollars and 34 dollars for shipping, for the wire I use "housing" wire (the wire we use in our house) that my father have in his garage... You understand now what we have a lack of research, replication, etc ?
If you don't have the money you can't conduct the experiment, if you can't make experiment, you can't analyse or correct your theories, if you can't correct your theories, your theories is just BS speculation, and if your theories is BS speculation you can't conduct the right experiments... ;D
This the true problem again: money, and since we are trying to break some 200 years old "conservation laws", no body will support you in your research, the last solution is to put your hard earning money...
This a one man against an entire army with a wood sword...   :o
So end of story, unfortunately...
