PLEASE PUT WORKING CIRCUITS only HERE (for everybody please give a share)
Started by Tito L. Oracion, March 03, 2009, 08:19:49 AM
gadgetmall
Hi . The most simplest Device came from Edward Leedskalnin . you can make this one with a Ubolt ,some wire and a battery . I find this topic of working circuits and thought it should be posted here . This is no more than a demonstration of perpetual energy that you can make therefor Flawed first and second law of thermodynamics states that perpetual motion machines of the first and second kind are   impossible. ;D Work is unseen electron Spin after power is removed.It dosn't dissapate over time ..Sometimes you can't see the snake that bit you becuase your standing on him and you can't see the tree because of the forest or you can't find your glasses because there on top of yur head;)
. It is made by wrapping wire abound the two legs of a u bolt . two coils  - and have a flat bar to place across the ends of the U bolt form a perpetual magnet and in effect accedendentally build a Torriodal Power Unit !All you do is energize it for a second and it will remain an electromagnet indefinitely until you break the flat bar from it's hold,breaking the Flow of the Electron Spin. Also you can put a ampmter in series with the coils in a closed configuration(a couple of diodes) after the dc power source is removed and show perpetual DC current flowing in a closed loop . Simplest demonstration of a TPU in operation . In a replication the user energized the coils with 10 amps and  6 amps remained in the coils after is off indicating a closed loop plus the magnetic  flow was also in a closed loop .for circuits and more elaborate designs see http://www.leedskalnin.com/. Also a borrowed v ideo from Lightsaber shown http://www.youtube.com/watch?v=S_ssUTRbRRs
and rwg http://www.youtube.com/watch?v=alnqltMb-pM&feature=related
Gadget
Tito L. Oracion
Quote from: gadgetmall on August 14, 2011, 01:03:15 PM
Gadget
i think we can combine the  captret of ibpointless here,  ;)
CompuTutor
...the ends of the U bolt form a perpetual magnet and in effect accedendentally (accidental)
(form a) build (of) a Torriodal Power Unit !
until you break the flat bar from it's hold, breaking the Flow of the Electron Spin...
Gadget
Study the rodin math system, wind one with silver plated iron, start the process, smile...
Hint: stay away from copper coated/cored/plated anything, always.
Silver can be plated directly to iron without interstitial metals.
http://books.google.com/books/download/A_complete_treatise_on_the_electro_depos.pdf?id=SI85AQAAIAAJ&hl=en&capid=AFLRE70SgK3RY4_KNFhSKEZvKqNXvCqs-NVh__N7QXqwvDab5RyK8MrStXqbjEQZgUkmV3iyEV080nFFHd3MB7Q6IyPmqxgN4w&continue=http://books.google.com/books/download/A_complete_treatise_on_the_electro_depos.pdf%3Fid%3DSI85AQAAIAAJ%26output%3Dpdf%26hl%3Den
A complete treatise on the electro-deposition of metals
The "Electron" people will now get all up in arms about this,
saying that the silver will short all the windings from electon flow...
EXACTLY (lol)!
What you want IS magnetic flow only.
If your winding simple form,
wind left to right one layer,
STOP and return to the left,
continue next layer left to right,
rinse and repeat...
Never wind like your going to use current...
Make sure all windings are from left to right,
with a right angle return to the left for these.
There is a much better variant,
the Tesla pancake coil of course.
Wind each layer bifilar (two wire),
erect a vertical buss for the starts/ends of all layers desired,
wire them to keep a sustained potential across bifilar pair like usual,
but only add additional pancakes to the existing busses to maintain this,
the above standard "Selonoid" winding does not apply here.
That winding method is only for launching
things exceptionally high from a cap only...
can you say "Edwin V. Gray", heheh ?
NO gradual windings back to the left.
I cannot say this enough to lazy winders !
Some will make the wire for you.
http://www.calfinewire.com/
Ever wonder why iron wire doesn't need to be insulated
while transering magnetic current in windings without shorting ?
CAUSE IT CAN...but removing all and any electron action is tops.
This is the section of things that just work,
these work, doesn't matter if we know why.
Google
Silver coated iron wire pancake bifi coils in a stack ?
Interesting, , can we get some details on how to wire them ? Series or parallel ? Where will the cap be added ?
Possibly a rough thumnail schema will help.
Best,
