First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
pese
Quote from: pyramidian on May 10, 2010, 09:36:19 AM
Hi guys,
i built a pyramid from your plan , V6
but after some accurate research i found this is just a radio,and nothing >:( ???
crystal radio needs ,quartz crystal earphone , graphite( for diode) ,coil , antena, ground connection, and some wiering
and it do not required an external power,
you used desert sand as  quartz, coil , graphite as diode , & condenser for filtering and routing electrons across the plates, to gather with the output condenser.
the pyramid's frame, works like an antena, you must turn it to find at least one radio stations,
and you need ground !!! :D
look at the links:
http://www.techlib.com/electronics/crystal.html
http://scitoys.com/scitoys/scitoys/radio/homemade_radio.html
http://www.google.com/search?rlz=1C1_____enIR328IR328&sourceid=chrome&ie=UTF-8&q=crystal+radio
http://en.wikipedia.org/wiki/Crystal_radio
http://www.google.com/images?rlz=1C1_____enIR328IR328&q=crystal+radio&um=1&ie=UTF-8&source=univ&ei=1wXoS_a4Lsa88gaM1vDxAw&sa=X&oi=image_result_group&ct=title&resnum=4&ved=0CD4QsAQwAw
you can replace the pyramid with a standard antena,
and you will see the results .
you can also remove the output condenser and place a crystal earphone instead, and listen your favorite  radio station bye turning the pyramid to right and left,
The TT "finds"
have nothing to do with radio or TV Waves from transmitters..
That signals are in any way to week (if you are not placed  in direct front of an VLW, LW or MW Transmitter.
TTs last "device" have delivered 29,5 watts.!!
(This was not more published, from himselve , because,
he have received, an lot of problems and disturbtion,
from different folks and systems.
I dont know the way, i have not the knowledge.
I am sure TT is seriosly, and have find an way, by experiments.
He, himself, dont understand the source of this power.
He live and will (can) not more work with this development.
He can not help.
Its need to do "experiment yourself", it is nothing to find in the WEB.
Pese
www.alt-nrg.de/pese  (german) including engl. Link Coillections.
www.overunity.de  "Pese"
gauschor
Why bump this old thing... you know his inner setup was a galvanic cell? Nothing special to it, the pyramid shape was as good as useless...
ytinurevo
If all of you did build a conform replica but got no results, it could be for the simple reason that your pyramid was not aligned to the North. In effect, no energy will manifest if the pyramid is unaligned, check the real pyramids over the world, they are all aligned.
It is not surprising that you didn't know this since it seems that Thomas didn't know himself as he says in his answer to an email "It is uncertain at the moment where this energy is coming from" and has he used rubber tape to mark several alignments meaning he didn't know which was best.
The other reason I see for you guys being unsuccessful could be that your pyramids are just built wrong. Get a book about the power of pyramids, build one as explained, verify that it has power, then, build Thomas system to convert the energy (torsion field ?) into electricity.
jeanna
Why don't YOU do that and post your results?
We went through the theory a lot (it is all in here the north and all the rest)
If you do have an answer to this and are willing to post it, many many people will replicate and appreciate what you share.
jeanna
