First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
11:11
i suspect that the great pyramid of giza,
worked similar to lord kelvins thunderstorm.
if the pyramid has 2 kinds chambers,
2 grand galleries,
2 separate water reservoirs outside the pyramid,
and 2 of everything else,
than its interior would even LOOK like kelvins thunderstorm.
kelvins thunderstorm having 2 buckets of water,
attached to 2 diagonal metal rings,
attached to 2 sources of dripping water.
both would have used water moving towards a "ring",
then water moving away from a "ring".
but kelvins thunderstorm,
just had a drop of water,
falling past a metal ring.
where the great pyramid,
would have used its ramp pump,
to spurt water towards an electrode,
that was sitting around the bottom of the great gallery.
the ramp pump drove the water upwards in spurts.
if there were about 6 seconds between each pump spurt,
than that would be enough time for gravity,
to pull water down the ascending passage,
and several feet away from the electrode,
before the next spurt from the ramp pump,
forced water back towards the electrode.
it would have looked similar to a wave of water moving up the beach.
then the wave of water being pulled down by gravity,
and back into the ocean.
the constantlywaxing and waning motion, of waves of water on a beach, might have been what inspired the pyramid builders,
to use electrostatic motion.
11:11
lightning bolts are created,
when a large number of electrons,
move away from the negatively ionized water in the sky,
and onto the positively ionized water on/above the ground.
the earth ONLY has positively ionized water on it.
the earth repels away electrons.
so that negatively ionized water can never sit on the earth.
for whatever reasons, the sky has negatively ionized water only, in it.
likely because the positive sunlight and the positive ionosphere,
attract so many electrons,
than all the sky's water/moisture,
is always negatively ionized.
lightning bolts are created by electrostatic movement.
just light a wimhurt machines lightning,
is created by electrostatic movement.
yet the lightning bolt can have 50,000 amps in it.
because the water in the sky is always negatively ionized.
and the water on the ground, is always positively ionized.
the unchanging ionization,
of the 2 bodies of water,
give enough time,
for a large number of electrons,
to move from point A to point B,
as high amperage.
the the metal on each wimhurst wheel,
is constantly switching,
between being positively ionized,
and being negatively ionized.
because nothing is forcing one wimhurt wheels metal,
to be negatively ionized only.
and nothing is forcing the other wimhurst wheels metal,
to be positively ionized only.
the wimhursts amperage is so low,
because the wheels change the ionization too fast.
the ionization reverses thousands of times per second, so the electrons are trying to move from A to B to A to B to A to B,
thousands of times per second.
instead of a large number of electrons,
moving away from the negatively ionized metal,
towards the positively ionized metal,
the electrons uselessly hover in the middle.
the electrons hover between point A and point B,
doing nobody any good.
in theory,
if you dumped sand or rocks,
into one of the buckets of lord kevlins thunderstorm,
than that would encourage the water in that bucket,
to be positively ionized water only.
but more electrostatic movement is happening,
the more surface area you would need,
of paramagnetic sand/rocks,
to fully correct the constant switching of ionization.
read my next post for more:
11:11
it is said that the ark of the covenant,
sat in the kings chamber.
was said to be a golden box.
that had a wooden box inside of it.
and the wooden box had a second golden box inside of it.
if the inner golden box,
had an extremely paramagnetic material inside of it,
such as uranium or plutonium,
than would cause the inner box's metal, to become extremely positively ionized.
electrons are attracted,
onto positively ionized metal/water.
if the inner box was sealed from the outside world,
than the outside box would become extremely negatively ionized.
if the inner golden box is ONLY positively ionized,
and the outside golden box is ONLY negatively ionized,
than that would allow large amounts of amperage,
to move from point A to point B.
without electrons uselessly hovering,
due to constant ionization switching.
but i think that they left,
the positively ionized inner golden box,
alone.
instead,
they used a massive reservoir of positively ionized water,
that was sitting outside the pyramid,
as the "positively-ionized-only" water/metal.
i have a busy life,
despite having very little income.
so i am not ready to show my incompleted work so far.
but i wanted to share some of the concepts,
that i have recently realized,
during my meditations.
for the sake of us all,
pass along whatever you find to be important.
it takes only the smallest spark,
in even a poorly configured nervous system,
to do something that counts.
hory
Hello Everybody,
Has someone noticed, what Thomas said, and did in the video? He said that in the reactor the inner and outer coil shold have wound in the same direction(cw and cw, or ccw and ccw). I watched the whole movie many times, but I think he wound the inner ond outer coil in opossite direction. (inner:ccw, outer:cw)
Regards.
Schauberger
What happened to this Thread ? Why did the discussion end in 2012 ?
Is there anyone out there who successfully rebuild this pyramid ?
Please contact me , thanks
