First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
Paul-R
Quote from: tao on December 05, 2007, 12:32:50 PM
Quote from: Thomas_Trawoeger on December 05, 2007, 11:02:32 AM
Hello outside there:
Well, our nice Servers and mirrors get bombed totally... Everything is damaged, all SQL?s are deleted, and if we take the backups to the Servers, everything is deleted in less than 30 seconds... (I am that sad, because you can?t see my tears in the eyes)
Well, we have to search for a better way to go ahead. Maybe we can go online this evening....
ng, Tom
(It seems to become "kindergarden" still on this site! Mr. KOEN, and Mr. PESE!)
Thomas,
Your faithful mod here!
That is horrible what has happened to the site, but it only confirms what we know about certain people that don't want information to reach the masses.
Don't kid yourselves.
Look at what happened to Fasthosts:
http://www.metro.co.uk/news/article.html?in_article_id=78426&in_page_id=34
Do you think the MIB are worried about Fasthost's collection of probable
consumer junk?
All manner of people get attacked. In most cases, it is the result of bad software
and incompetent Network Management. Use proper staff  and systems and the
problem may well go away.
Paul.
slapper
Hi Thomas and all.
I'm normally a lurker behind the scenes performing proof of concept of the works going on in this forum.
I just wanted to say that I have the deepest respect for what you and the contributors are going through.
My post is to stand up and be counted as standing beside you and your efforts. My belief is no different than many others on this forum. The more we disseminate information and keep it in the public domain the safer we all should be. The fact that you are getting attacked only solidifies your credibility and encourages me to study this information more. We are all stronger in numbers and we need to get this information out of the genies lamp as much as possible.
My two cents. Love to all. You are in my thoughts and I know for a fact that I speak for many. Take care.
nap
we are not alone :)
Lofty
Alternatively a simultaneous post on several servers at once. Co-ordinated.
Then it is impossible to try and stop them all in one go ;D
Then another simultaneous post and another and eventually "they" will give up. They only have limited resources we have 7 BILLION people behind us, all wanting a better life and planet ;)
"They" are only actually puppets trying desperately to serve the Masters in their dying days.
Look around on all the forums, they are losing it big time. Everything they have worked towards has started to fall apart or be exposed. 8)
"They" are in their Death throes
Keep the pressure on :o
Lofty
vipond50
Hello Thomas & Working Group
I was glad to here from Thomas and he is still working this project.
I am sorry to here that the alarms are still ringing and the red lights are flashing, but the project specifics will be
posted all in good time. I agree with the idea of multi posting at the same time to various sites. Doing so would make it more difficult
to stop. There are various site around the globe that would love to assist in this.
I feel, Thomas is handling this problem and has some excellent advisers on hand for this.
I am rambling  (sorry)
I am concerned also like all on the group and will continue to construct.
God be with U Thomas and the Group
Best Regards
neptune
Message for Tinu. Here are some things to check. I am not the expert, but check these anyway.
1 Is   the level of 5% salt solution correct[5% by volume not weight] and have you allowed at least 1 hour for excess solution to escape.
2 Is the pyramid aligned with one side of the base North-South, and the copper tube frame of the converter East-west.
3Have you checked that there is no contact between graphite rods and copper frame
4 how did you connect wires to the graphite rods, could they have come disconnected during soldering the tubes. Could you have broken the rods during assembly. In my opinion, it is best not to solder the upper joints, as this allows you to take it apart for inspection.
5 Have you remembered, on the main capacitor, to connect all the positive plates together and all the negative plates together?
6Have you tested both capacitors for short- circuits?
7 Does the output wire leave the converter running towards the north, and sloping down at 40 degrees to the horizontal.
8Have you tried a different sand? Do not use children's "play sand". because this is not sand, it is crushed limestone.
9
Check your coils, because it is easy to make a mistake here. If we wind each coil starting at the
top,we must wind one coil clockwise, and one anticlockwise[ counterclockwise]
10 using a Ohm meter, check all of the circuit for bad joints
11 Starting up. Turn pyramid away from the north. now connect load[DC computer fan , 6volt 3to5 watt lamp, or 8ohm resistor. turn it to north and give it time to work keep load connected when using multimeter to test voltage.
As I say, I am not an expert. Just hoping I may have helped.
