First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
skywatcher
I have measured the angles and added then to the picture.   :)
Although i think they should be correct, i would recommend making a paper model before cutting steel.  ;)
olivier
skywatcher
duff
@skywatcher
Actually I wasn't working on the apex but I was going to tackle that next.
Could you show the lengths also. I think you will find that they change with the angle.
Thanks for your help!
-Duff
neptune
I have just noticed a small detail on my V6 plans which I had overlooked. Has tinu done the same. Where the wires from the graphite rods exit the tubes, the diagram shows an insulator.[wine bottle cork?I had planned to leave these out as not necessary if insulated wire is used. Now I just noticed, The sand fills the top horizontal tube as well.Thomas says the graphite rods must not be fixed at the bottom[free to vibrate?] He does not say it, but perhaps they must be free at the top also. My plan is, make U -tube fill with sand, insert rods.fit top tube and T pieces, threading wires through exit, insert insulators. Do not solder tubes here. drill a small hole in top of top tube, fill with sand. Seal hole with wax, glue, tape etc.. Hope this helps
